turn signal problem
turn signal problem
my front turn signal lights and side marker lights do not work. my head lights and break lights and read turn signal lights all work. whats wrong with the fronts? the turn signals have 2 new bulbs but the side marker lights do not.
So the front turn signals and the corner lights don't work? Is that it? Do ALL the rear lights work in the taillights?
I know the headlights are on their own fuse and the taillights I believe...might be a blown fuse from when you put in the new bulbs.
you can check them with a multimeter if you have one. Or the relay or fuses might have gone out. Check the side bulbs first. You should be able to look at them and tell if they are any good.
this is on my 87 4runner. every light on this truck works besides the turn signals and side marker lights, tomorrow im going to try everything and see it i cant get this to work.
rushw
07-18-2015 01:46 PM
