| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
#2 (permalink) |
A blower and a turbo are 2 differend beasts. A turbo is driven by the exhaust and a blower is belt driven. One of the biggest problems in adding a turbo is heat...
Chuck |
#3 (permalink) |
there is actually a turbo that came stock on some of the 22r engines... this of course turns it into another designation though....
#4 (permalink) |
wasnt the turbo something like 22re-t? I saw one at a junkyard that my dads friend owns, he said we could have whatever we wanted. I asked about the truck and he said it was already spoken for. Bummer, would have been sweet.
__________________
Rig: 1982 longbed pickup 31" tires Diff breather mod (1st mod ever on 4-30-04) |
#5 (permalink) |
Thanks for the replies. I think what I'm looking for then is a blower. Doesn't it force air into the intake? I was wondering if anyone knew where I could find one for a 22RE, or is there any reasons why you wouldn't recomend one. Thanks for the help.
#6 (permalink) | |
Quote:
__________________
#7 (permalink) |
Thats fine, the extra power would be worth the extra money, hehe. I wonder if there's some universal blower for Toyota trucks, or any automobile?
#8 (permalink) |
No universal blower, of course, each has to be made specifically to fit the engine. There is/was a blower for the 22R, (actually from a couple of different companies) but I've never saw one for the RE. You could change the head and do the blower on the RE, but you would have to go to carburetion rather than FI. (If it wasn't for this I would have done it on my 85, but I will never own another carb engine.) Camden, B&M make blower kits for the 22R, or did at least.
THe RE-T engine had a lot of differences besides just the turbo. The turbo compressor itself is easy enough, but the systems that keep it from destroying the engine quickly is well beyond the tinkerer's capabilities. Wastegate control, detonation control, changing fuel/air requirements etc. LC Engineering has turbo kits for the 22R. http://www.lcengineering.com/TurboKits.htm Oh check this out! On their What's New page, LC Engineering now offers a blower kit for the RE! http://www.lcengineering.com/Whatsnew.htm
__________________
All my Yotas are gone. Stuff to sell: http://www.yotatech.com/showthread.p...39#post1009839 -Phil Last edited by Flamedx4; 06-13-2004 at 09:50 AM. |
#9 (permalink) |
what i think the main problem with running a blower? cost! i don't understand how something that's not really all that complicated(or at least it seems) can run over $2000
however, you also might need to run forged pistons and upgrade your injectors...
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts past toys: 1984 4x2 1979 4x4 1991 4x4 |
#10 (permalink) |
THANKS! Wow, thanks for all this input so quickly. I appreciate it! So LC makes the super charger for the 22RE. (The "E" stands for EFI right?) That's great, I would really like to get that kit for my truck and boost its horsepower. What kind of injectors would you recomend I upgrade too? Are there any other precautions? I'll probably look into forged pistons, because I'll need something stronger to handle the power. Thanks again guys, you've all been a big help.
#11 (permalink) |
From my experience, you can get away with low levels of boost on a stock motor with stock components (no forged stuff). But thats on a healthy motor with no existing problems and doesn't have a bunch of miles. (Also, that experience is based on GM motors; more qualified Toyota gearheads than myself would have to answer whether that holds true for your 22r/22re motors.) However with low levels of boost you won't be seeing a lot of the power your looking for. But, if you wanted you could start with a tuned down supercharger (read: low boost) on a stock motor and run that until you got the money to dump in the components that would allow you to turn your boost up.
__________________
Cory Eastern OK, Western/Northern AR, Southeastern KS, or Southern MO area: OZARKS 4ROC Click Here 04 Dodge 2500 Cummins - DD/Tow Rig 02 Z06 Corvette - Weekender 94 FZJ80 - Wheelin Rig. Build in progress: http://ttora.com/forum/showthread.php?t=129727 72 Buick GS - i.e. the project that will never get done. |
#12 (permalink) |
__________________
2005 Toyota Tacoma Access-Cab 4x4 w/ TRD Off-Road Package 33" Goodyear MTR's 3" Toytec Lift Clear Headlights Quick Pic of the Taco My Old Toyota 4Runner Limited, Check It Out! |
#13 (permalink) |
Got $6,300+ for the supercharger motor from ToyotaPerformance? Then add to that all the other changes necessary to get it up and running
Unless you really need some freaky power and have $ falling out your it doesn't seem like much of an option. Even if you only bought the supercharger, all the changes required add up fast. You can get around 145hp out of the 22re for far less and for a little truck that is pretty sufficeint. Check out LC's motors for an idea what to build and maybe just get a head from them and do the bottom end locally. If you can do some work yourself the $ savings add up. |
#14 (permalink) |
Thanks again. The engine still runs perfectly - like most Toyotas. It only has 84,000 miles on it as well. Looks like I'd better start saving my $$$.
#15 (permalink) |
Just a suggestion: If you are going to spend that much money, maybe you should think about doing a Supra engine conversion. Try searching for it on this site. There should be a lot of info.
#16 (permalink) |
my '84 2wd pickup flew with it's 22R. i couldn't possibly imagine a 7MGE or 7MGTE(turbo)
__________________
#17 (permalink) |
Before I spent that kind of money I'd put a FI small block Chevy in it. They're cheap & plentiful, easy to work on, easy to hotrod. Install kits are available to make it easy to do. If you resist the urge to use too much horsepower, the trans and tcase will live with a stock small block.
__________________
All my Yotas are gone. Stuff to sell: http://www.yotatech.com/showthread.p...39#post1009839 -Phil Last edited by Flamedx4; 06-14-2004 at 09:27 AM. |
#18 (permalink) |
or do this
![]() http://cgi.ebay.com/ebaymotors/ws/eB...&category=6059 i might do this when i get the 6L and 4L80 tranny and swap it in my silverado. and then swap the my old v8 and tranny into the yota
__________________
1989 22RE Toyota Pickup - Custom Intake 2002 Chevy Silverado - Magnaflow Cat back, UPD Intake, Custom Tuned, B&M Tranny Super Cooler, Vette Servo, Toyo Proxes, 6000k HIDs 1995 Acura Integra - AEM Intake, Tein Basic Damper Coilover Kit, Skunk2 Front Strut Bar, EM Racing Rear Strut Bar, EM Racing Pillar Bar, Beaks Subframe Tie-Bar, Suspension Techniques Rear Sway Bar, Skunk2 Camber Kit, 6000k HIDs |
#19 (permalink) |
chevy guts in a toy? that's blasphemy! :pat:
__________________
#20 (permalink) |
So, you'd rather it was Ford?....
__________________
All my Yotas are gone. Stuff to sell: http://www.yotatech.com/showthread.p...39#post1009839 -Phil |
#21 (permalink) |
Got a quote back from LC yesterday on the SC for my 1991...THEY WANT $27**. for it! Yikes! More than I expected for a 4 cyl. I was hoping sub 2K.
__________________
2002 Stellar Blue 4Runner Sport Edition Cold Air Intake Magnaflow Exhaust Iridium Sparkplugs Kenwood KDC-MP628 Blaupunkt Separates in all of the doors Two RF P2002 amps Kenwood 12" Subwoofer My baby: Pics |
#22 (permalink) |
Well, if I were to forget the blower, I wonder if a hood scoop would be possible. Has anyone installed one on there truck before? It'd be 10 times less expensive. Just wondering how much of a difference it would make? Thanks for all the input.
#23 (permalink) |
Why would a hood scoop make any difference in how it runs?
__________________
#24 (permalink) |
I'm saying, if I installed a functional hood scoop, would that additional forced air make a substantial difference in the trucks performance. Because air would be blown into the intake when I driven. Just wondering if it's worth it.
#25 (permalink) | |
Quote:
__________________
~Todd 2001 4Runner V6 SR5 4x4 , Sway-A-Way Racerunners , Old Man Emu rear shocks & coils |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 86 Pickup Turbo Parts Needed | RICKY24 | 86-95 Trucks & 4Runners | 4 | 10-12-2007 05:50 PM |
| New rig - 86 Turbo Pickup | Bill | 86-95 Trucks & 4Runners | 18 | 02-08-2007 09:12 PM |
| 86 Toyota Turbo Pickup for sale | Hodakaguy | The Classifieds GraveYard | 6 | 09-20-2006 08:56 AM |
| TEC Turbo Kit installed - 86 Pickup RTEC | Hodakaguy | 86-95 Trucks & 4Runners | 3 | 09-04-2006 01:44 PM |
| New rig - 86 Turbo Pickup | Bill | 86-95 Trucks & 4Runners | 1 | 08-29-2006 05:23 PM |
