Tuning open loop Q' w/R4 ware
During deceleration-open loop, AFRs jump to 17-20-if not higher. Should I increase the cell value on the fuel map for this area? I am just finishing closed loop tune...I am assuming I would move the cell value in the same
direction for WOT-open loop-with high AFR reads, correct?
thx in advance!
98/sc/390cc/walboro
thx in advance!
98/sc/390cc/walboro
AFR's jump REALLY high during deceleration because your pumping the engine.. its not a problem and I dont it anything to do with you running open loop. My brother's turbo Civic does the same thing and its closed loop.
Edit: as long as it doesnt ping, I think youre OK.. I'd check other tuning sources though.
"Under very high vacuum (deceleration conditions) run 15.5:1 or 16.0:1 AFR's or even fuel cut on deceleration to prevent lean exhaust system backfiring."
- How to Tune and Modify Engine Management Systems by Jeff Hartmen
Longbed 90
10-19-2015 11:05 AM
Odin
09-26-2015 06:56 PM
runnermedic
13
09-21-2015 05:20 PM
