Tundra Upgrade Price...Pretty darned Affordable
I just wanted to let everyone know that rockauto has some great prices right now on all the Tundra brake upgrade stuff.
I am able to get two refurbished semi loaded calipers, pads & rotors for just about $250 after sending back the cores.
Below is a little excel snap shot showing the breakdown with part numbers.
And no, I am not shilling for rockauto, but their prices are simply the best I have found anywhere. All local stuff was well over $300 bucks.
EDIT: This is for the 231mm setup. 13WL
Last edited by Man4God; 10-02-2012 at 12:07 PM. Reason: Forgot the size part. Doh!
Great... now I have no reason not to do this upgrade. My brakes pulse like hell going downhill and everything was just replaced not too long ago. Im wondering if I should just wear out my current stuff or do the brake upgrade now. Hmmm..............
I just redid my brakes and they are shuddering as well. All it takes is one panic stop or not being perfect on bedding in the new pads and the bastards are warped.
If it was me, and literally it could be me based on what you wrote, just go ahead and get it done.
Unfortunately, I have no idea. But I can't imagine that the spindles are much different than what the Tacos have.
Here is what I would do. Go on to Rockauto, write down a couple of the 2006 Tundra 4.7l brake parts (calipers & rotors mainly) and compare them to what they pull up for the year T100 you have.
It's really not that expensive. Mind you, I just ordered the stuff. I will need brake fluid and go through the PITA of bleeding the brakes. But I KNOW it will be worth it.
...and I am considering the 231mm upgrade. Is that what you went with or the 199mm? I am just a bit concerned over the spacing between the caliper and rim.
ZPD, I'm running power slot rotors on the front of mine. They feel a lot better than the factory rotors, especially on stops from higher speeds or heavy repeated braking. I've also got factory pads, but was considering trying a set of EBC's or Hawk pads in the future.
It really is something for me to consider. I go up and down a few big hills to work everyday and when your going downhill at 60mph and the light changes at the bottom of the hill its a battle to stop without the friggin pulsing. I referred to this writeup... http://www.toyota-4runner.org/3rd-ge...tml#post835439
Yeah still running stock rims. This is my truck so im assuming I would have to do some grinding although the end of the article I posted has a list of stock wheels that will work, just not sure if mine fall under that.
I say they will clear.
I hope they clear mine. Since mine come on that generation Tundras, I would hope so. Now I need to look for another Tundra wheel for a spare. Didn't see that part about the spare not fitting.
Now if one used the 199mm caliper vs. using the 231mm would you have the same clearance problems? I know the 231 is going to be a step above but would the 199 should still provide better braking then the stock caliper?
I never even thought of that. Good point! Double work might not be worth it in my case if I got a flat tire on one of NJ's insane highways with traffic rushing by in the rain....
From what I have read, the 199 still had issues. Don't forget, the Tundra had warping issues that we have on our 4Runners and I don't see there being much of a difference in weight between the two. I do think the biggest benefit is the thickness of the rotor and ability to cast off heat & handle heat to begin with.
All I know is that I am willing to make the sacrifice because I am tired of the crappy brakes. I drove around with squeaking, scratchy breaks for a year because I was so hesitant to do a break job, not get something perfect and deal with crappy brake shudder.
I will be looking for a 17" replacement wheel & tire. Shouldn't be too hard. CL is one click away!
kawazx636
10-06-2021 03:03 PM
FS[MidAtl]: 2000 Tundra (Parting out) Pennsylvania
ToyotaMD
11-09-2015 11:53 AM
LCE_Performance
10-01-2015 01:03 PM
4runnerFireman
09-29-2015 06:24 AM
