TSB for my 02 Sport
TSB for my 02 Sport
Hi guys,
I just stopped by the local Toy dealer for a check up on my "Door weather strips". It keeps loosing out/dropping down some sort like that, if I stretch it and put it back it will likely stay there for a few days then the same things happen again.
So they checked it then told me that it is covered under the TSB. So they ordered it for me.
Hope I can share this.
Same story here
Same problem with my 02. First it was the ft pass door, I took it in, was good for about 6 mos, and its crumby again - pulling from the top rear corner like the seal is too small.
Now 3 of the 4 doors are affected.
I'm wondering if it's worth taking it in or devising a fix on my own....
Location: Home: Aurora, CO; Work: The People's Republic of Denver
Sparman,
If its covered under a TSB, then let the dealer do the work for free.
2002 SportEdition,
Does this effect only 2002's or are there other years covered?
2002 SportEdition,
Originally posted by rwmorrisonjr
Sparman,
2002 SportEdition,
Sparman,
2002 SportEdition,
Hey Guys,
I immediately noticed the same problem with my '02 Sport shortly after bringing it home. The front passenger side door and rear drivers side door weather stripping was drooping a falling off. I took it to one dealership and they just applied more adhesive to the weather stripping. This worked for about a week and the problem recurred. I took the 4 Runner to another dealerships and I was informed that the weather stripping was too short and it was a factory defect. They had to order the replacements and they did replaced them under warranty. I was not told anything about a TSB though.
Echo
Echo
Echo
that sounds like a TSB since they are aware of the issue and are already fixing it without giving you any problems. the # would be good so we could all get some new weatherstripping
*** bump (round two) ***
Anyone have any more info on this TSB yet?? I contacted my dealer yesterday about my sagging door seals. They ordered 2 seals for the front doors, but said they needed to verify my rig fell under the TSB. I like to have details (TSB #, info) before the works starts just in case they try to give me the run around or try making me pick up the tab AFTER the works already done. They haven't provided me with any TSB info yet....
Are the rear doors covered as well??
I have the same problem on my rear driver's side door. My local dealer replaced weather stripping under warranty 2 times already. I have 2001 4Runner SR5 by the way...
-- Andrey
-- Andrey
**They said that they will replace all 4 doors.
Lam.
Got a TSB number
Hi guys,
I picked up my rig today, the dealer replaced all 4 strips and other necessary stuffs for the doors. Everything looks good now. here is the TSB number: BO001-03 (B-O-Zero-Zero-1 - Zero-3)
Good lucks,
Lam
Good lucks,
Lam
Big Little Bear
230
11-13-2023 11:42 AM
jacked_72
09-14-2015 03:31 PM
