YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 10-20-2005, 09:18 AM   #1 (permalink)
4Peanut's Avatar
True or False? All aftermarket 16" wheels will rub calipers on a 3rd gen 4Runner
Stopped into a local 4x4 shop this morning to get a price on a set of 16x8 Mickey Thompson Classic II's for my '96 4WD 4Runner. They told me that the Classic II's would rub the calipers, and I would have a problem with any 16" aftermarket wheel. They suggested I step up to 17" wheels, but my 285/75 16 BFG AT's are no where close to needing replacement.
I've been on yotatech for almost two years, and I've spent the last hour searching the forums. Is this really an issue? Is everyone out there with aftermarket 16" wheels grinding their calipers (but not telling us)? Can anyone recommend a 16x8 wheel (not black) that fits without clearance problems?
4Peanut
__________________
1996 4Runner SR5 4WD
Front Suspension: OME 91S/881 + 2 pairs of bamachem's spacers Rear Suspension: OME N86/891
Tires: BFGoodrich AT KO, 285/75R16 Wheels: OEM 16x7
Rack: Yakima Crossbars and Load Stops
Fun: Hidden Hitch Round Tube that pulls a 1999 Malibu Sportster LX
4Peanut is offline
Sponsored Links
To remove this ad, register today!
Old 10-20-2005, 09:22 AM   #2 (permalink)
99_Runner's Avatar
Send a message via MSN to 99_Runner
I don't know what they are thinking, but if your 4Runner came with 16" wheels from the factory, then a 16" rim won't rub the caliper no matter who makes the rim. A 16" rim is a 16" rim.
__________________
Drew
99 4Runner SR5, auto, 3.4 V6, factory rear locker, 265/75 Yokohama Geolander AT+II
Stock for now, but hopefully not for long.
99_Runner is offline
Old 10-20-2005, 09:24 AM   #3 (permalink)
Keggo's Avatar
Sounds like they just want to make a quick buck. Plus... offroad tires in R17... isn't that pretty expensive?? Like 99 Runner said "A 16" rim is a 16" rim..."
__________________
- Kevin E. G.
SOLD!!!
'91 4Runner SR5 V6 5spd: CLICK!! FOR SALE NOW!
Proud dad of Kai E. G.!
Keggo is offline
Old 10-20-2005, 09:26 AM   #4 (permalink)
Send a message via Yahoo to bamachem
they aren't talking about the outer edge of the caliper, but the face close to the hub.
all you have to do is take an angle grinder to the caliper high spots and then hit w/ some rattle-can and then most 16" aftermarket wheels will fit. the strength of the caliper isn't comprimised by the grinding, by the way.
bamachem is offline
Old 10-20-2005, 09:59 AM   #5 (permalink)
4Peanut's Avatar
Quote:
Got it. Is it enough to prevent the wheel from being mounted? In other words, could I drive out of there and just let the wheel grind down the caliper itself?
Has anyone had a shop do this for them?
BTW, bamachem, my initial reason for stopping into the shop was to schedule an appointment to have them install the two pairs of top out spacers I bought from you. I am finally going to get my 4Runner sitting level.
I'd still be interested in hearing from anyone who has installed 16"x8" aftermarket wheels on a 3rd generation 4WD 4Runner without having to grind down the calipers.
4Peanut
__________________
4Peanut is offline
Old 10-20-2005, 10:02 AM   #6 (permalink)
most shops won't do it due to being afraid of liability if something were to happen.
you can't drive off. the wheel is locked to the caliper if they don't clear.
this is common w/ the tech1 rockcrawler wheels.
bamachem is offline
Old 10-20-2005, 10:19 AM   #7 (permalink)
SC4Runner's Avatar
I have the 16" wheel calipers and have had no problems with fitting 16" rims.
I've heard people grinding the calipers to fit 15" wheels, but, never 16"?
Why dont you just have them stick some on and then show you where they will rub.
SC4Runner is offline
Old 10-20-2005, 11:19 AM   #8 (permalink)
99_Runner's Avatar
Another thing you have to remember is to get the right backspacing. I guess this is what they are talking about.
__________________
Drew
Old 10-20-2005, 11:42 AM   #9 (permalink)
Unhappy99's Avatar
16 inch rims are NOT all alike.
Differences in offset (backspacing refers to the same), shape of the spokes, material thickness, etc., all play a part in 'will it fit or will it rub'.
That being said, there are many 16 inch wheels which will fit.
__________________
03 Dodge Ram 2500 CTD...its amazing
Ex: 1999 4Runner JT3HN86R1X0199261...Now somebody elses Karl Malone Toyota 'Certified' POS
Legendary Toyota quality is exactly that: A thing of legend.
Defective fuel gauge - 'Certified'
Defective brake rotors - 'Certified'
Defective axle seals - 'Certified'
Defective heater diverter - 'Certified'
etc. etc. etc.
Unhappy99 is offline
Old 10-20-2005, 11:50 AM   #10 (permalink)
JGM
JGM's Avatar
I have the 16x8 tech1 black rockcrawlers (4.25" BS) and never had a problem.
__________________
1996 4Runner & 1971 FJ40
JGM is offline
Old 10-20-2005, 01:12 PM   #11 (permalink)
Flamedx4's Avatar
{{if your 4Runner came with 16" wheels from the factory, then a 16" rim won't rub the caliper no matter who makes the rim. A 16" rim is a 16" rim.}}
Not true.
You nailed it. Assuming the correct backspacing, the differences in the shape if the wheel (the "style" if you will) from one wheel to another can indeed cause one to rub when another doesn't.
__________________
All my Yotas are gone. Stuff to sell: http://www.yotatech.com/showthread.p...39#post1009839 -Phil
Flamedx4 is offline
Old 10-20-2005, 01:44 PM   #12 (permalink)
grimpy's Avatar
Send a message via AIM to grimpy
Get the wheels with a 4" BS... When you get them, take off one of your front wheel and bolt the sucker on, try to spin it. If it spins freely then you are good. If it gets stuck, then you will need to either grind down the caliper or get some small spacers to push it out a little further.
__________________
2007 Tacoma Double Cab 4x4 TRD Sport 6speed
Pro Comp 6" - Bilstein 5100 front
18x9 Moto Metal 951B - 325/60/18 NTG
Pro Comp Skid - Lund Grill Cover
17x10 Weld EVO Velociti 6 *soon
grimpy is offline
Old 10-20-2005, 01:48 PM   #13 (permalink)
4Peanut's Avatar
Quote:
Now, can anyone with a '96 4Runner post the 16x8 wheels they mounted without caliper clearance issues (I realize this may be a small subset of the yotatech community, but Mickey Thompson told me that Toyota changed the caliper from '96 to '97).
So far, I know that Tech1 Rockcrawlers and MT Classic II's won't fit without grinding.
4Peanut
__________________
4Peanut is offline
Old 10-20-2005, 03:11 PM   #14 (permalink)
Gangus2006's Avatar
Send a message via AIM to Gangus2006
4Peanut
Our Runner came with 16" wheels stock, and I have American Racing 16x8 Victors on there now. No grinding. Actually, I can fit my hand in between the caliper ad the spokes, where, witht he stock wheels, a hair could barely fit.
Gangus2006 is offline
Old 10-20-2005, 03:24 PM   #15 (permalink)
JGM
JGM's Avatar
4Peanut
Not true. See my post above.
__________________
JGM is offline
Old 10-20-2005, 04:13 PM   #16 (permalink)
Albuquerque Jim's Avatar
I have 16" MT Classic Locks...they fit fine.
__________________
'00 SR5, "Highlander"
Dual Cases, Aisin Hubs, E-Lock'd, Cryo'd, Chromo'd, ARB'd, 315's, Sonoran Steel Bumper, Lift & UCA's, 4 Crawl 1" BL, Armored...etc.
F-Toy #081 in progress
Dual Cases, 30 Splines, 5.71's, E-lockers, Hydro-Assist, 37's, DOM Hendrix Chassis, 80Proof, ORS, Sonoran Steel...etc.
Albuquerque Jim is offline
Old 10-20-2005, 04:28 PM   #17 (permalink)
Sponsoring Member
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
It all depends on the backspacing...as I've had several sets of rims and (1) set rubbed on my 3rd gen, the other didn't, the difference was a 0.25" of backspacing that made all the difference. Get out a tape measuer and see what you got and match it to your new rims.
waskillywabbit is offline
Old 10-20-2005, 06:42 PM   #18 (permalink)
ebelen1's Avatar
Like others have said above, it's more a backspacing issue than a rim size issue. I have a 3rd gen that came with stock 15" wheels and upgraded to 16" aftermarket wheels w/no issues.
ebelen1 is offline
Old 10-20-2005, 06:53 PM   #19 (permalink)
Bluedog's Avatar
I have the black alloys but they do make silver.
http://www.wheelersoffroad.com/toyblackalloys.htm
__________________
2005 Tundra iForce V8 4WD
American Racing Teflon Mojave's. Pirelli Scorpion ATR LT 265/75 R17
1995 FZJ80
Wheeler's 16 Black Alloy Wheels.
Bluedog is offline
