truck goes down the road sideways
i dont know why but my truck goes down the road at an angle.. the back tires are way out of line from the front ones. the steering wheel has a big turn to it but the truck still tracks straight. the rear axle is also not straight; the tire is farther back on one side than the other. any ideas? whats going on? thanks in advance.
Almost sounds maybe bent frame too ?? hmm wierd for sure
Any funny wear on the tires ??
Have you had the rear suspension out of the truck recently, or changed springs. I have seen this when a friend installed new leaf springs and put one side in backwards. The axle mount was not centered, this put one side of the axle ahead of the other and caused the truck to 'crab' to the left.
It's called dog tracking the back tires are not following the front, my friends suburban did that, he was towing a 25,000 lb boat and pulled the body off the frame, he eventually had to have the body welded back onto the frame and it fixed the problem.
Usually you see it on work trucks or vans, anything that is hauling heavy loads and beat on sooner or later dog tracks
if you have "jammed" the rear tire into somthing latley, you could have sheared off the center bolt in the leaf pack or bent a leaf, another cause is that your u bolts could have came loose and allowed the axle to drop down enough to pop over the center bolt, get under it and look, it should be pretty clear of what happend
yeah, i have seen other trucks doing this too... just didn't know what was going on. i dont think i've hit anything, but you never know. i was just trying to find the center bolts but couldn't find them on either side. :wtf: maybe it will be easier when its daytime out. ...i guess i will have my mechanic look at it soon.
thanks for the replies!
How long have you had the truck, do you know any of its history?
PS: After rereading your original post, I noted in your sig line that a lift kit and new shackles were installed. Maybe the shackles were installed incorrectly and this caused the springs to be mis-aligned to the frame?
thanks but.. no.. all this happened much after the lift was installed..
ive had the truck almost 2 years, and i dont really know the history before that. i know i hit a tree with it, but that was about a year ago... or more actually.
some !@#$er who was trying to pull me out with his bronco was tugging really hard on my bumper a little while ago, and it bent the arb forwards... so maybe its related to that... but i didn't notice the alignment being @#$@ed up until at least a couple weeks or a month after that. i just gotta get some money so i can have the shop look at it, i am completely broke right now.
im just really hoping its not the frame...
7-7-04
now its alive again at 8-24-04, yikes the world must be coming to an end with all these old threads coming back from the dead.
Scofco, I say being you live in rust country your frame is ˟˟˟˟ed. Time to get a Kia Sportage man.
7-7-04
The frame wasn't very rusty at all though.
I did clip the front right wheel on a mound of ice awhile back, it was an awful feeling. Perhaps that warped the frame?
Booo!
Booo!
duckhead
07-17-2015 04:45 AM
