Troubles while replacing rack and pinion..
I bought a remanufactured rack and pinion from autozone today cause mine was shot. The rack and pinion came with instructions on how to bleed the system, 3 o rings(2 the same size, 1 smaller one) and of course the rack and pinion. I guess the o rings go in the feed and return ports? But it is unclear, since there are no o rings on the fittings into the R/P now? And why are there 3 o rings if there is only 2 ports? Anybody know any info on this?
1996 4Runner 3.4L 4wd
And yes, I searched.
I am suppose to run Paytte Draw saturday, I need this thing done tonight. Thanks for any help..
The online manual does not show any o rings on the P/S lines going into the R/P gear, it looks more like compression fitting, similar to a brake line into a caliper. So why is there o rings in the box? Anybody?
I have never done it, but this may help.
See this link :
http://www.autozone.com/autozone/rep...00c15280262020
They show a picture of it, anyway ...
Good Luck !
Britt
Good Luck !
Britt
Poncho0206
07-10-2015 06:21 PM
Avenged
07-09-2015 07:55 AM
