Trouble Removing Steering Rack
I have two problems, any help would be awesome. My first problem is the unpressurized line to the rack. I cannot get it off. I've tried line wrenches, regular wrenched, I've even tried the locking pliers (I thought I'd just replace the fitting once I got it out). Any suggestions?
And I was also wondering what other bolts/nuts I need to take out. I know... I know... I need an FSM. Please take a look and tell me what to hit up next.
Thanks. -Nels
Thanks. -Nels
Last diagram.
http://www.ncttora.com/FSM/2003/Repa.../ntsc/remo.pdf
It only looks like you've got one of the B bolt out, not A
Ya thats what I thought, put 6" fabtech lift in I'm starting to think the pressure extention line that they gave me might have a kink in it. Blown three pumps so now I'm replacing the pump lines and rack, just don't want to put it all in and have the same problem. By blowinhg the pumps, I mean to say, I finished lift install fired up tried to bleed pump blew, replaced fired up blew again, same with the 3rd. I can't even get started on wheel turning. Figure either line is kinked or the rack is done.
delmert
09-30-2015 04:34 PM
priest16
15
08-06-2015 07:43 AM
defrag4
07-31-2015 10:50 AM
