Trimming to fit 35's
I am planning to run 35's on my 98 4runner. I am currently in the process of installing a 1.5 in body lift and sonoran steel #1 suspension lift. Having a little problem with the f...ing rear brake line but thats a different thread. My current rims and tires are currently sitting against my front a-arms so I have had to order the rims and tires and bring them home to install them. How much of my front fender wells need to be trimmed and what is the best method of doing this? I can't weld yet and I think a sawzall will jump around a lot. Any recomendations would be greatly appreciated.
what rims and tires do you have?
http://www.trailslesstraveled.com/ar...y-lift-height/
same concept. i think there is the same type of article floating around featuring a 4runner.
yeah I think Sean at TLT did the runner i think, no BL on it so you get the jist of what kind of trimming he did, now you wont have to do as much since you will have the 1.5 inch bl. though it will be necessary
justdifferentials
09-05-2015 06:52 PM
anniesball
09-05-2015 08:45 AM
