trick to install tumbler?
Old 11-29-2011, 09:55 AM
billkmiami's Avatar
Question trick to install tumbler?
What is the trick to install the tumbler portion of the key assembly between the key tumbler and the ignition switch behind the key assembly- closest to the firewall- I had the key tumbler and the ignition switch removed- I was installing a new ignition switch- when I removed the old ignition switch, I heard a spring release noise and the "mid tumbler portion" (between the key tumbler and the old ignition switch) :popped" out of place- not sure how to reinstall the mid tumbler correctly- what am I missing?
1997 4-Runner- 170K miles- thansk!
westonian18
05-01-2020 06:38 AM
okamikai
04-30-2018 10:19 PM
Hamonacracker
07-17-2015 08:33 AM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: trick to install tumbler?
