trembling engine
trembling engine
I have a 4 runner 95 V6 Auto.It has not stoped trembling since a bought it.I changed the fuel filter,cleaned the TB,changed the plugs,PCV and wires.But the problem does not go away.Is also loosing power.I'm even using the best gasoline.Don't know what the problem is.A friend of mine told me that it might be one cylinder is not working well.Can anybody help me if you understand me now.Do you need more info?
Yeah, try compression testing it. Also, you might have a vacuum hose loose or something. I was cleaning out my throttle body one time and a hose came loose that I didn't see. Started the rig up and sounded like it was missing. After a long search, I discovered that a vacuum hose had come loose right under the throttle body. Re-attatched it and it ran like new.
jasonty
41
12-23-2018 01:00 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
