TRD boost gauge accuracy / calibration????
I just installed my boost gauge this weekend and it is only showing 5.5 - 6 lbs of boost at WOT. I was under the impression that the S/C should put out in the 7-8 lbs range. But I noticed that when I turn off my engine it reads "-1". I was wondering if the means that everthing will read 1 under where it should?? Because that puts me closer to the correct range. Any way, is there a way to recalibrate this thing??
Or is my charger (1st gen gray) not putting out the proper pressure... :cry:
mine goes to 7-8psi...what are you using for the boost source for the gauge? I'm t-ing off the port right off the sc that goes to the fpr.
Does anyone else's read -1 when the engine is turned off??
check out my sig pic...my boost gauge is actually a hair over 0 but still in the white of the 0 marker...I will check today and try to get some pics of WOT and turned off.
Originally Posted by yoda-g2
That's the same port I'm using.
Originally Posted by SLC Punk
Mine does. It maxes out at 6 psi. I also have it T'ed at the FPR
I'm just wondering that since its at -1 when the engine is off, if that means its reading 1lb less than it should aka 6 = 7. I'm just glad to hear that others are only reading 6lbs.
ashamsuddin
17
01-13-2023 03:17 AM
LCE_Performance
10-01-2015 01:03 PM
