Transmission valve upgrade - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-28-2007, 07:45 PM   #1 (permalink)
ninjarunner's Avatar
Ok I don't want to hear the retarded answers about "If you don't do the upgrade you will destroy the tranny". I have had my Runner supercharged for just over a year, I just bought the URD 7th Injector kit, I talked to a guy a while back who did a $6 upgrade with washers to his tranny that was supposed to do the same thing as the upgraded valve would do but obviously for way less. what is anyones thoughts on this if anyone is familiar with this or not, let me know. I don't want to blow the thing and have to get it rebuilt. as of yet I haven't had any problems I have been pushing these big A tires for awhile as well.
__________________
99' 4Runner - Silver - With ECT button
Custom 6in lift, 315/75/16
Supercharged with URD fuel upgrades and smaller pulley
ninjarunner is offline
Old 11-28-2007, 08:34 PM   #2 (permalink)
id go on the safe side and do the valve body upgrade.
the only bad thing about it is that it has some down time because you have to send your valve body to level 10 or IPT so they can change the springs in it or whatever.
im sure with 35's and a supercharger, your tranny has alot of stress on it.
__________________
1999 4runner Limited 4x4 - E Locker - SS #1.51 Kit - King 2.5" Coilovers - 285 Mickey Thompson Baja MTZ's - Stubbs Sliders - Alpine 9883 Deck - Shrockworks Front Bumper
TRDrunner is offline
Old 11-28-2007, 08:44 PM   #3 (permalink)
j-man's Avatar
i had my 03 tacoma dbl cab supercharged for 25k miles, and when i first put it on, the tranny was fine. But as i approached about 10-15k miles on it, it was definately not shifing clean gear to gear, and with the added power of the blower, your auto trans really heats up. Hook up a temp gauge on the line coming out of your tranny, and youll see temps frequently hit 230-240 degrees which is a killer. Go ipt, its a $500 tranny insurance, drop the valve body out yourself and ship it on a monday to ipt, they get it tuesday, should have it done by wed/thurs latest, then overnighted to you on friday and re-install. After you get it done, youll probably be able to chirp tires in second, and youll sleep well at night not wondering when your trans is gonna have to be rebuilt.
__________________
2000 4Runner v6 sr5 4x4 5spd: Turbo'ed
99 4Runner v6 Sr5 4x4 5spd: Saw's / OME combo TrueTrac rear
98 4Runner V6 Sr5 4x4 5spd E-locker: Saws / OME combo... EEZI AWN Roof Tent 1.4m
97 4Runner V6 Sr5 4x4 Auto: Saws / OME combo TrueTrac rear
2003 Landcruiser 285 BFG At's and outback roofrack
My Baja Trailer Build: http://forum.ih8mud.com/showthread.php?t=179520
http://community.webshots.com/user/bajaroadtrain
j-man is offline
Old 11-28-2007, 08:47 PM   #4 (permalink)
j-man's Avatar
oh yea, they not only install stiffer springs, but bore it out to allow fluid to circulate faster and better, as well as new clutch plates that hold up. IT stays much cooler combined with a tranny cooler - hayden 678 or 679 (the bigger the better) mounted in front of your radiator. You also have the option of having them give you springs for a "harder" shift, or a "softer shift" - its up to you.
__________________
j-man is offline
Old 11-28-2007, 09:40 PM   #5 (permalink)
The one thing I have never taken apart on my rig is an auto tranny how hard is it to get the valve body out?
__________________
Old 11-28-2007, 09:57 PM   #6 (permalink)
never mind just found a post on it, as long as I can do it with the tranny still on the truck I'm good.
__________________
Old 11-28-2007, 10:24 PM   #7 (permalink)
Call IPT and ask to speak to John. He will take the time and answer all your questions.
__________________
2001 4Runner 3.4V-6 SR5 4x4 | 16x,xxx miles | Stock auto grenaded planetary gear mod | IPT Built A340F stripped Planetary gear mod | Tranny #3 good luck | Stubbs SKO sliders | Bud Built front skid | Trail Carnage belly skid | Rockware rear bumper | Goodyear MT/Rs | | OME 882/890 | Trekmasters | Detroit Locker rear | Truetrac up front | 4.88s
2008 FJC TT SE 6 SPEED
naksukow is offline
Old 11-28-2007, 10:29 PM   #8 (permalink)
apalmer1's Avatar
Screw sending it to a shop for nothing more then valve spring upgrade. Use a magnetic tiped grabber and lubricate the bores with assembly lubricant and ATF, ensure the magnetic grabber is totaly level and pull straight out gently rotating as you do so. If you are careful you can remove the valves without any damage, just be extremely slow and delicate and stop at the slightest sign of resistance.
I removed and checked all the valves in both a TH350 and 4T60E this way, as the local tranny shop wanted too much money to do it for me.
However maybe your tranny shops are more reasonable...
__________________
04 taco, 3.4 5spd. loads of goodies, FZJ80 axle SAS in progress.
85 pickup, 327sbc, truggy, in progress.
86 mazda b2000 street queen haha.
92 mazda B2600i 4x4 absolutely mobs.
81 ford bronco drinks gas
90 mazda mx-5 all original.
when in doubt, tach it out.
apalmer1 is offline
Old 11-28-2007, 10:39 PM   #9 (permalink)
CJM
CJM's Avatar
FWIW, dont skimp or your trans maybe toast.
I have personally been to both shops and actually had each shop work on my 84 corvette (they had to machine and rebuild the rare 4+3 doug nash trans) and I love thier work. I guess I am lucky they are only an hour from my current house and were 20 minutes from it before
I love both shops, they do excellent work or I wouldnt let them near my car. That trans is very rare and they dont make alot of parts for them anymore so understand.
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks.
Be polite. Be professional. But, have a plan to kill everyone you meet.
CJM is offline
Old 11-29-2007, 04:55 AM   #10 (permalink)
tomstin's Avatar
This should help you understand what it takes to remove and replace the valve body http://members.cox.net/mgriese5/Level10.html
__________________
2001 Tacoma SR5, V6 Auto, Perma-tech bed liner, Gaylord lid, Deck plate, Amsoil fluids, Hayden Trans cooler, Supercharger, Level 10 Valve Body, URD Fuel Mod, RAAMmat/Ensolite Sound Deadening
tomstin is offline
Old 11-29-2007, 04:59 AM   #11 (permalink)
tomstin's Avatar
Some additional reading http://www.customtacos.com/forum/sho...ght=valve+body
__________________
tomstin is offline
Old 11-29-2007, 09:21 AM   #12 (permalink)
I just spent the last hour reading on the "upgrade" the supra guys are doing, thanks for the info. I'm going to do it when I get a chance I'll post on here how I went. I don't have the fat cash it would take to send it to IPT so we shall see if this will be good with 35's.......
__________________
Tags
a340f, tacoma, transmission, upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
valve body upgrade spaugh General Vehicle Related Topics (Non Year Related) 3 06-05-2006 08:58 AM
Valve body upgrade travelinman 95.5-2004 Tacomas & 96-2002 4Runners 3 01-06-2005 10:18 AM
What's in a valve body upgrade? midiwall 95.5-2004 Tacomas & 96-2002 4Runners 33 07-15-2004 09:18 PM
Don't Understand Valve Body Upgrade trdracer 95.5-2004 Tacomas & 96-2002 4Runners 6 08-25-2003 01:01 PM
IPT Valve Body Upgrade!! ravencr 95.5-2004 Tacomas & 96-2002 4Runners 24 07-17-2003 10:15 AM
2009 InternetBrands, Inc.
