Transmission plugs - what size socket?
Originally Posted by Flygtenstein
How about 22 or 24 mm?
I would be impressed if you have standard fittings on a Toyota.
My manual tranny only took a little less than 3 quarts. Manual says it holds 3.2. Tranny was hot and on level ground. Anyone else replace theirs lately and it take less than the book says it should? Must not have gotten it all out cause its right at the filler hole.
Oh, and my buddy's 15/16 worked just fine.
My t-bar bolts are 22mm which means the tranny and axle drain and fills are 24mm by process of elimination. FYI, the low pro drain plugs for the diffs are a PN for tranny plugs.
Using SAE on metric fitting is just begging for trouble.
Some SAE sockets work equally well on a metric. I think 13/16 is the same as 17mm. I found that out when installing Hella auxillary lights and the manual said use either one. It was true. I needed a 17mm deep socket and I only had a 13/16, so that's what I used. It fit exactly.
However, its a lot more practical to forget about using SAE on a Toyota. Buy some good metric tools. Consistently trying to find the right SAE on a metric vehicle is not practical in my opinion.
BTW, my tranny uses a 24mm drain and fill plug. Whatever size yours is, use a 6 point instead of a 12 to avoid rounding the head.
I use 15/16 on mine too, do you guys have magnetic drain plugs on your transmissions? I have magnetic ones on the transfer case, front & back diff., but not the tranny...
Originally Posted by BigBadBlue
12 points suck arse
