Transmission noise
Transmission noise
I get a noise when i shift the tranny lever to L. D to 2 is fine, but 2 to L makes a noise. It can only be heard if the window is down, radio off, and its quiet. The noise is difficult to describe, its sort of like a "squeezing" sounds or "burbing sound", the sound you get when grease is squeezed through a small opening.
Havent had the opportunity to crawl under and listen/watch while someone else shifts the lever.
This ring a bell for anyone?
Ok, I just went out and tried putting mine in L and sure enough it makes the same noise you described. Only mod to my tranny is the cooler, so I guess it's normal unless someone else says otherwise.
crammit442
7
11-29-2017 12:30 PM
mengquis
07-13-2015 10:39 AM
Poncho0206
07-10-2015 06:21 PM
