Transmission lines for external cooler?
Old 03-15-2010, 09:02 PM
twitchee2's Avatar
So im doing some stuff ive been wanting to do a for a while finally found some time. The big one is my transmission. Im installing a external cooler I got out of a 1-ton dodge so im making it work. my question is what kind of lines do i need to get? Can i just use some fuel line or vacuum line or something else? Im going to be dropping the pan and changing the filter in there. Other then that im going to redo some wiring for my lights and things of that nature, then doing the bagel mod. Anything else i should look into?
So main question is what kind of line should i use to the trans cooler?
Old 03-15-2010, 09:09 PM
Staff
DeathCougar's Avatar
Use transmission cooler line, of course.
It needs to be line made for oil. vacuum line will not work.
Old 03-15-2010, 09:19 PM
twitchee2's Avatar
that makes things simple....way to simple.... thanks
chuckross1957
06-28-2019 10:19 PM
4x4-runner
08-30-2015 08:55 AM
this_guy
07-31-2015 01:27 PM
jjrbus
07-17-2015 07:06 AM
Snort
07-09-2015 03:58 PM
Quick Reply: Transmission lines for external cooler?
