Transmission Damaged Bad??
Old 06-27-2003, 05:09 AM
vtruong1's Avatar
Well,
Last night scared the $#@! out of me. I towed my bass boat to friends house to get worked on. His drive way is really steep and I tried to back the boat up into his driveway to drop it off. 3/4 way up the hill, the tranny grinded, pretty damn loud in reverse. I stopped, drove down and had my buddy take it up with his 1500 Chevy.
You guys think that there was some major damage to my tranny?? BTW, its an 99 3.4 Automatic
Please let me know, thanks a lot
Old 06-27-2003, 05:15 AM
TOR
Tranny
Not a good sign, when was the last time you had the tranny fluid completely flushed? Have you checked the color on it after that incident? Some things to think about.
Todd
Old 06-27-2003, 06:35 AM
rimpainter.com's Avatar
Yeah, we need more info. What's the history on the vehicle? How many miles? Maintenance performed? Etc...
Old 06-27-2003, 06:43 AM
vtruong1's Avatar
Sure thing.
Its a 99 Limited 3.4 liter V6 Automatic. Has 50k and I flushed the transoil at 45k and filled it with Amsoil. Diff and trans case flushed at about the same time with Amsoil. Engine oil is changed every 4k miles with driveshaft lube. Hope that is enough info.
I forgot to mention that the car shut off after the griding, but started right up again. What you guys think? I just got this bass boat so I havent been towing it a lot.
Old 06-27-2003, 06:47 AM
Are you still under warranty?
Old 06-27-2003, 06:49 AM
vtruong1's Avatar
yeah i have an extended warranty until 150k or 5 years.
I dont notice any damage when driving, but really not sure what the inside of the tranny looks like.
Old 06-27-2003, 06:53 AM
TOR
Tranny problems
Hmm, checked with my techs out in the shoop and we haven't heard of anything like that. One thing though, my heavy line tech said if it shut the engine off it should have a code on it. Almost always if the engine shuts down the computer will have a code or two explaining what it is Even though you don't see any lights or warnings. Their recomendation would be to get it to a dealership ASAP! With that low of mileage and proper maintenance you got a problem somewhere. Hope this helps and let us know what you find out please.
Todd
Well, I wouldnt want to be left stranded, so I would get the Runner into the shop ASAP. Most likely they will be unable to duplicate the problem unless one of the tech's has a bass boat
Seriously though, with that kind of warranty coverage, and the desciption you gave us, I would have it checked out right away.
I never had a problem with my Auto tranny on my 98, and I treated it like I was a tester for Consumer Reports.
Old 06-27-2003, 06:56 AM
TOR
Tranny issue
I concur.
Todd
Old 06-27-2003, 06:59 AM
vtruong1's Avatar
I have a warranty from warrantygold. they have been great. I got the bumper to bumper coverage so the transmission is covered, just dont know what the deal is on towing.
i dont have a problem taking it in the shop, but like you said, how can they diagnose the problem. i am hoping that the damage is minimal, like a bad stick shift driver griding gears hahaha. any more thoughts?
Old 06-27-2003, 07:00 AM
You should still be covered under the 5 year 60K Toyota powertrain warranty.
TOR
Tranny
No they probably won't be able to duplicate the problem. However, they can run the diagnostics on it and see if there are codes that show up. I would highly suggest doing this ASAP.
Todd
Old 06-27-2003, 07:01 AM
Actually, you should hope the damage is HUGE. That way you will get a whole new tranny instead of a rebuild to the effected part.
Old 06-27-2003, 07:09 AM
vtruong1's Avatar
yeah i ill take your advice, ill go check it out. good call on the powertrain warranty. ill let you guys know what happens. thanks for the quick ass reponses.
Old 06-27-2003, 08:11 AM
vtruong1's Avatar
question, will there ge a code if there is no check engine light?
Old 06-27-2003, 09:02 AM
TOR
Tranny Issues
Like I said sometimes there are codes even if there aren't check engine ligts on. Happens all the time here at the dealership.
Todd
Old 06-27-2003, 09:08 AM
Sac State's Avatar
5 year, 150K mile warranty? How much did you pay for that! I am shocked any private company would have a warranty exceeding 100K miles.
Old 06-27-2003, 09:10 AM
Its a Toyota man! C'mon you know better.
Old 06-27-2003, 09:13 AM
Sac State's Avatar
I know a Toyota will run 5 years or 150K miles with no problems, been there done that, but a warranty?!?
Old 06-27-2003, 09:26 AM
TOR
Warranty
We don't need no stinkin warranty man!
Todd
Quick Reply: Transmission Damaged Bad??
