Transmission Cooler Hose Route?
OK - stupid me. I am re-assembling my 1991 3vz after buying remanufactured heads - not a job for the impatient.
In addition to the factory manuals, I have a Chiltons (not very good) and Mitchell PC manual. I also took a ton of pic's as I disassembled. It didn't occur to me to take pics of the bottom of the radiator, however.
I am staring at the two hoses (one longer and straight, one shorter and curved) that each run from the bottom of the radiator to their own metal pipe coming from the tranny. They carry transmission fluid.
I don't know which one goes to what metal tube.
Thanks in advance,
David
p.s. everything they say about the ridiculous exhaust crossover headaches is true.
Thanks in advance,
David
Originally Posted by Marc
If I've hooked mine up correctly ther right rubber hose goes to the right metal line. Left to left
I don't see an electric or a mechanical one?
Unless you have an aftermarket aux trans cooler, it doesn't matter. All the trans cooler in the radiator consists of is a small piece of tubing which the fluid passes thru. The direction of travel doesn't matter.
this_guy
08-10-2015 10:44 AM
Poncho0206
07-10-2015 06:21 PM
