Transmission cooler?
Old 01-05-2004, 06:51 AM
r854rnr's Avatar
this may have been covered (this is almost a typical response now!) but I can't find anything.
A while back a saw somebody doing a transmission cooler for their 3rd gen tranny. I was curious if anybody knew where I could read about it/ get a write up for it.
Also, what are your opinions on this? is it needed, recommended, waste of time...?
Old 01-05-2004, 07:42 AM
rwmorrisonjr's Avatar
Location: Home: Aurora, CO; Work: The People's Republic of Denver
Use the flashing green button of knowledge at the top of the screen. There are numerous write-ups on tranny coolers for the 3rd Gen 4Runners.
Old 01-05-2004, 07:44 AM
waskillywabbit's Avatar
Hayden Tranny Cooler
2000 4Runner - Hayden Tranny Cooler write-up
http://www.drawhorn.org/hayden_trann...er_writeup.htm
Easy to do yourself!
Hope this helps!
Old 01-05-2004, 07:52 AM
Senior Member
jacksonpt's Avatar
I've got the TRD cooler on my 96. Complete writeup and pics on my website (see my sig for link to my site).
Old 01-05-2004, 08:14 AM
midiwall's Avatar
Absolutely recommended if you do any slow-speed off roading. Crawling around through rocks, up grades, etc. will cause a good amount of strain on the tranny and limit the airflow through the radiator (which has an inner chamber for the tranny fluid as well).
The Hayden 1678 _is_ the cooler that Toyota sells under the TRD badge. Bulkpart.com sells them for $43.79 which is about 1/3 the cost of the TRD branded version:
http://www.bulkpart.com/cgi-bin/miva...egory_Code=HCS
I didn't need anything extra outside of what was included in the kit. It installed in under an hour.
Good luck!
Mark
Old 01-05-2004, 08:18 AM
Robinhood150's Avatar
The search isn't working right now, see the sticky at the top.
Old 01-05-2004, 08:22 AM
r854rnr's Avatar
Thank you for the information people! Exactly what I needed.
I really appreciate those of you that reply with opinoins and quality information!
irv
10-01-2015 09:49 PM
ToyotaMD
09-22-2015 06:28 AM
briholt
09-20-2015 10:26 PM
TransAmBandit
09-20-2015 06:08 PM
kelly1450
09-02-2015 12:29 PM
Quick Reply: Transmission cooler?
