Transmission Cooler 2004 Pre-Runner?
Help! I know this is my first post but, I got a little freaked-out..
I saw the helpful photo on the installation of a transmission cooler. I own a 2004 Tacoma Pre-Runner. I installed a Hayden a few weeks ago. Also, I switched out the fan coupler as I read in this forum. The question is, I am not sure if I installed it correctly? I am getting confused with the return line ...With my vehicle, is on the drivers left? As in the article here. Or is the line on the drivers right??
Thank you in advance and thanks for responding..
Does this link help?
https://www.yotatech.com/forums/f128/trd-transmission-cooler-3rd-gen-4runner-76336/
It has a picture showing which is which.
Thank you! Yes, that is the exact same write up I used in order to install it. Nice photos which helped tremendously!!
Not to But, I also read another article that on some Toyota trucks, typically the 4-Runner, the retrun line was on the drivers right..
I did test it afterwards and unplugged the line while the engine was running. The fluid was running out fast..I didn't realize how much pressure is those lines
Thank you once again..Lost in confusion..
Ilovemountains
09-15-2015 04:17 AM
Highlander Giant
09-08-2015 06:46 PM
