Transmission Bolt Size, HELP!!!
So I thought my clutch was bad but it ended up being weirder but easier. Apparently I didn't torque down some of the transmission mounting bolts hard enough... so 3 on the bottom drivers side are gone. This is making everytime i push the clutch down seperate the engine and transmission instead, probably like 1000lbs seperating them or whatever it is.
But...
Does anyone know the bolt sizes for these mounting bolts? I think there are 2 large ones and one small one.
I don't know exaclty if there were nuts and bolts or just bolts but if they are coming out i may just get a long one and put nuts on the other side.
But I don't really want to drive it to the store to find out the sizes so if anyone knows the sizes it would be excellent,
Thanks,
Alex
But...
Thanks,
Alex
If the head of the bolt is a 14mm, the thread size should be 10mm x 1.25. if the head is a 12mm, the thread should be 8mm x 1.25. that should be your two sizes.
kgcwb44
01-29-2023 10:02 AM
whereAreMyPants
07-22-2015 03:32 AM
4runner, 69, 87, 95, 96, bellhousing, bolt, bolts, dimension, size, tacoma, thread, toyota, transmission, transmisson
