Sign in using an external account
| 95.5-2004 Tacomas & 96-2002 4Runners 4th gen pickups and 3rd gen 4Runners |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
Transmission Acting Weird - 2002 4Runner
__________________
2002 Runner Sport 1988 Pickup - Utilitarian Extreme Model |
#2 (permalink) |
Personal
Sales Rating: (0)
shudder under light acceleration while in overdrive is common when the spark plugs are old and the gap has widened. If they are old I'd replace them and the wires first and see if that cures it.
__________________
1996 SR5 4WD Auto Toytec Ultimate with OME 890's plus 10mm spacer 60028 OME shocks Treadwright Guard Dogs 265/75 -16 B&M 70268 with Magnefine filter |
#3 (permalink) |
Personal
Sales Rating: (0)
[OP]
kball - I'll give that a whirl, I hope it works cause the dang ole plugs and wires add up to $250.
This is very possibly my problem...my idle has been getting rougher. Just today, I thought keeping it out of O/D was working and now i'm seeing the studder happen out of O/D as well. It almost seems to be worse than the original studder in O/D.
__________________
#4 (permalink) |
Personal
Sales Rating: (0)
If it's happening out of O/D then it's probably not just a plug/wire issue. And they should not cost anywhere near $250. $50 is more like it. Unless you're talking about having a shop do it.
__________________
#5 (permalink) | ||
totally a bro
Personal
Sales Rating: (2)
Staff
check your coolant and your transmission oil. The cooler in the trans is known to leak. Otherwise check the plugs
__________________
92 toyota truck sc'd 3.4, URD 7th injector kit, 2.1 URD pulley, 5spd, 4.30 gears, E locker rear, magna flow cat and muffler, 2 1/2 pipe, isr mod, 1" BL, trail gear sliders, 1.5 bjs front, sway away torsion bars, add a leafs and 2inch lift shackles rear, rancho 5000 265/75/r16 nitto terra grapplers, xrc8 winch in front bumper, rhino lined bed. RB4R- SAQuote:
Quote:
TREADLIGHTLY Possibly end your existance for a dollar? |
| Tags |
| 2002, 4runner, 50mph, antifreeze, shuddering, transmission |
