Transfer case woes: 99 4Runner
Old 03-21-2010, 06:56 PM
Yukon's Avatar
Scouting mission tonight, got stuck was giving it some gas in 4x4, felt a thud kind of thing. like if you were disengaging 4x4 under a little too much load
Thats when the 4x4 stopped working.
its the x-fer case, front ADD stuff engages and is fine.
in the parking lot 4 hi and low don't work and don't grind. the push button (99 limited) makes a grinding sound.
I changed the output shaft seal maybe i didn't torque the nut on that enough?
any ideas?
Sorry for being short, one handed typing due to broken finger. If I cant ride my bike, OR 4x4 for a month im gonna go crazy
Old 03-21-2010, 07:01 PM
Yukon's Avatar
How do you even drop the x-fer case. I assume im gonna need to open it up
Old 03-22-2010, 05:14 PM
Yukon's Avatar
bump??
Old 03-22-2010, 06:12 PM
j-money$$$'s Avatar
i broke my transfer case awhile back, and i pulled the trans and trransfer case out at the same time. I have a stick so i was going to do the clutch too.
Old 03-23-2010, 11:52 AM
Yukon's Avatar
ok, in 2wd everything is fine, no noise.
when i use the pushbutton 4x4 (no locked center) the output spins, and makes a grinding sound. in 4hi, the output spins, and makes no sound....... but doesnt work under load i have to assume as it wasnt spinning when i got stuck...
it all actutes fine, and the lights all turn solid on the dash. really hoping to get a good diagnosis before i drop the case as then my truck will be out for at least a week.
Yukon's Avatar
No metal in the fluid...nothing visibly wrong from the top of the case
Old 03-24-2010, 10:24 AM
Yukon's Avatar
More diagnosing.
only grinds when shifting into AWD (push button on 99 limited)
The output shaft spins in all modes after it has shifted in. Once spinning, the case doesn't make any funny noises.
I think it has to do with the electric motor on the back of the case. Does that come off? How?
I took off all the bolts to it, and it wouldn't come off even with a moderate amount of prying.
Old 03-24-2010, 10:44 AM
Yukon's Avatar
Looking at the fsm.. it looks like the actuator is the culprit.
i doubrt i can fix it without dropping the case.. And thewn I probably might as well buy a new one and be done.
crap
Old 03-24-2010, 01:10 PM
Yukon's Avatar
Well final update. I'm buying a new case. If anyone knows of a 99-00 Limited case for sale let me know!
Old 03-24-2010, 01:34 PM
Fossilized
Staff
dropzone's Avatar
Toyota Truck Dismantlers: body parts/axles etc
The Toy Man (newberg, OR) http://www.thetoyotaman.com/
MazToy (troutdale, OR)http://maztoy.com/
Davez Off Road: http://www.davezoffroadperformance.com/
Yotayard (colorado) http://www.yotayard.com/home.htm
Jim's Got Parts (Denver, CO) http://jimsgotparts.com/
California Mini Trucks (Cali) http://www.calminitruck.com/
NIX99 (washington state) http://nix99.com/
Rancho Toyota Truck Dismantler (Cali) http://www.ranchotoyotatruckparts.com/
ToyoKings (FLA) http://www.toyokingsusedparts.com/
Toyota Parts (Colorado SPrings, CO): http://www.toyotacarpart.com/default.asp?i=home
Yotatech Classifields :https://www.yotatech.com/forums/f91/
TTORA Classifieds: http://ttora.com/forum/forumdisplay.php?f=3
Pirate classifieds: http://pirate4x4.com/forum/forumdisplay.php?f=4
Parts Locators: http://www.autopartslocator.com/
http://www.seekautoparts.com/
BeMiceElf
10-10-2015 09:40 PM
Tykiller1994
08-10-2015 07:49 PM
A2theK
07-12-2015 10:46 AM
crashburnoveride
07-10-2015 06:39 AM
skoti89
07-06-2015 07:45 PM
Quick Reply: Transfer case woes: 99 4Runner
