Transfer case fill plug part #?
Hey all,
I searched and didn't see this so sorry if it is on here somewhere. I need the part number for the transfer case fill plug and gasket (?) if anyone can help out.
It is for a 1997 4Runner V6 w/ auto trans. I took it in for an oil change and the dude said the plug is just gone (prob. previous oil change they did not replace it).
So I need to flush the transfer case and refill it, but need to order the plug assembly first so I have it.
Thanks!
Thanks!
Go to YotaYard on Walnut St. near downtown and yank the plugs out of a case there. I just dropped my old T-case off there a couple of weeks ago with both plugs in it. I say that just to say that I know they have T-cases laying around there, and I'm sure you could find one there for less than you'll pay a dealer parts center for them.
Here are the part numbers for the fill plug and gasket for the transfer case in case anyone else ever needs them:
fill plug 90341-18006 ~$3.00
gasket 90430-18008 ~$1.00
CB
CB
Hopefully you didn't go up any really steep hills... you could've lost quite a bit of your fluid, and be driving around with a really low level in the transfer. Good thing the oil change guy caught it when he did... hopefully no damage was done.
i think he meant the bolt is being rounded off. The bolt can get rounded pretty easily if not open properly. I like to use impact for to untighten at axially position, prevent from rounding.
In regards to being clear, I was. My plug is gone as in not present! I topped up the transfer case fluid and got another plug to put in already. Need to flush it out and refill still though.
CB
CB
Crap! I was right. (That's worse for you than if I was wrong.) How much gear oil did you have to add when you topped it up? (PS. I apologize for assuming that you weren't clear.)
06-01-2021 01:51 PM
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
