Trans cooler question
Does the Radiator have a dual core coolant/trans? I looked under the runner and saw the fluid lines running to the bottom of it.
Is this good enough for towing or is another cooler recommended? I will be towing a uhaul 6x12 trailer later this month and want to make sure its ready to roll.
Thanks,
Jeff
Thanks,
Jeff
Tranny cooler is a must unless that trailer won't be loaded with anything and you are just driving around the corner. You can just grab one at Napa or somewhere and have it on in under an hour.
I am going to order the trailer lights kit from Etrailer, anyone know which transmission cooler I should get from there? What size fits the best?
Thanks,
Jeff
Thanks,
Jeff
An extra in-line tranny cooler or even a bypass cooler is ideal for towing and or regular driving.
There are extensive threads on here regarding transmission coolers and the types recommended. Please search this.
I got mine from Derale. It's run in series with the radiator cooler and a remote filter with an oversized K&N filter. adds another quart of tranny fluid to the whole system. I run around 180 degrees pulling a 2000 pound boat.
this_guy
08-10-2015 10:44 AM
Poncho0206
07-10-2015 06:21 PM
