Tranny Trouble
Old 11-29-2004, 01:41 PM
91 4Runner's Avatar
Tranny Trouble
I go out to the 4Runner today to go into town, put the truck into reverse and nothing (hmmm I says to myself) try drive (OK there) try reverse (nope) try neutral (goes forward on it's own - no hill) give her a little bite - definatly in gear but no reverse) Check fluid, it's OK. Check linkage - set correctly. So I push the truck out of the driveway and take it to a tranny shop - diagnosis - Shot. Spent the rest of the day tracking down a tranny $550 for the tranny 101 day warrenty(used tranny from a wreckers) and almost 550 more to have it installed... POS A340H
Old 12-04-2004, 02:25 AM
91 4Runner's Avatar
Well a few days and $1200 Cdn and it's now fixed.... I was informed that heat was the cause, so I had a tranny cooler installed in line with the factory one.... Now the question is why didn't the A/T Temp light come on?
Old 12-04-2004, 03:01 AM
MTL_4runner's Avatar
I can't say why the light didn't come on, but make sure to change the fluid on a regular basis (like a drain and fill every 35-40k KM) and you will extend the life of your tranny much farther than otherwise. Glad to hear you already put in a cooler which will also add miles to the new drivetrain's life.
Old 12-04-2004, 07:36 AM
Babypig's Avatar
Did they try to pull a code first. It could have been as simple as replacing the lockup solenoid or a PNP switch. If you had been having trouble with it then it may have physically failed but if it went all of a sudden i would suspect electrical failure first. Easier and much cheaper to replace a solenoid or switch rather that R&R ing a tranny. Could even be the TPS.
Old 12-05-2004, 03:59 AM
91 4Runner's Avatar
What they told me(3 different mechanics) is tat some of the plates welded themselves together due to heat....
ladybugRC
458
08-21-2020 10:41 AM
TheBFA
02-15-2020 06:55 AM
live4soccer7
05-11-2016 06:52 PM
Davebarbier
11-03-2015 03:28 PM
voiddweller
10-02-2015 07:47 AM
Quick Reply: Tranny Trouble
