Tranmission Flush procedures for 02 4runner
I want to do a tranny flush and fill to my sons 4runner(automatic) I know there is a procedure that involves removing the cooling lines, but I have not been able to find the link for this. I have used this procedure on my powerstroke, but I do not know which line is the return line to the tranny. I believe it is the line that connects to the rear of the tranny, but i would like confirmation. Thanks in advance.
Is this what you're looking for? http://www.amsoil.com/faqs/atf_and_f...procedures.pdf
That helps some, but I would really like to know which line is the return line to the tranny. I know there is someone out there who knows these things inside and out. Maybe I am in the wrong section. Thanks tomstin for the link. I use a modified version for my Superduty.
The rear line is the return line.
https://www.yotatech.com/forums/f128...4runner-76336/
http://www.gadgetonline.com/TransFlush.htm
This guy did it earlier in the year in this thread
https://www.yotatech.com/forums/f2/a...l#post50781771
I believe the front line on the AT is out (hot) and the rear is the return (cool), but easy enough to check, pull one off, put it in a bucket, add a little pigtail of hose to the barb, place it in another bucket, start the truck for 10 seconds or so, that will tell you what way the fluid is pumping. That's how I confirmed the fluid direction when I installed my AT cooler.
Flying91
45
04-11-2024 04:39 PM
the1998sr5
15
07-14-2020 08:35 PM
FS[PacNorWest]: 1987 Toyota 4Runner $1800 Whidbey Island, WA
coreyedwards7611
01-16-2016 06:38 PM
BeMiceElf
10-10-2015 09:40 PM
