Trailer hitch bolt-up
I'm mounting a class III Reese hitch that came without hardware. How much trouble am I begging if I rely on the 4 towing hook bolts only as hardware to mount the hitch? Only plan to do light occasional landscape towing/bike rack type stuff. If I really need to do the two other bolts at the front how in the heck do I get the bolts in and through the frame? Any tips to share?
Thanks for any input...
I took one off tonight.
4 17mm head bolts and then the ones closest to the front are nuts on studs. The studs are welded to plates slid up in to the frame. Pull them out with a coat hanger easy and put in place by sliding them in from the end of frame. Nothing to it.
Take 10 minutes tops to install. I ripped it off in about 45 seconds with an impact and it hit the shop floor with a loud clang.
:wabbit2:
:wabbit2:
I wonder if those studs welded to plates are available at the dealer? Sounds like a simple solution compared to getting a bolt in there that may tend to spin when I tighten the nut...
1 Post
I would not tow with just the rear 4 bolts. A bike rack should be fine.
My stock hitch was held on by those bolts plus 4 more (2 on each side) toward the front. Mine had 2 nuts welded to a metal strap that was slid into the frame (the end of the strap reaches to the rear of the frame rails). Then the bolts are threaded into them from below.
Go to or order them from a hitch store. You could make them if you can weld.
The bolts for the rear holes are M12x1.25x35mm. There is an access hole in the side of the frame rail to get the nut in place over the hole, but those plates with welded nuts that slide into place sound much easier.
RyanJ989
11
04-07-2021 09:41 AM
Cycles
09-29-2015 06:37 AM
potatopants
09-15-2015 06:26 AM
mirabile4runner
09-03-2015 07:15 AM
