| New! Use your Facebook to securely log into this site, click logo to login |
| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Trac off/ Vsc Trac lights came on, need help!
__________________
2002 4runner |
#2 (permalink) |
It means the computer has a trouble code. Get the codes read and you will know what the problem is. If you have an Autozone nearby I heard they'll do it for free. Or if you're near my house I'll do it for a
![]() Otherwise you can buy a code reader, or take it to a shop and pay $75 or so.
__________________
2001 4Runner; 4.30 ratio 1999 e-locked rear axle and front diff; OME881/N91S front; OME891/N86 rear; BudBuilt skidplate and bellypan; Tundra brake swap; 1" 4Crawler body lift; 4Crawler SliderZ; TJM T-15 with Warn M8000 winch and Amsteel blue synthetic line; 170 mm Lightforce lights; dual batteries with Hellroaring battery isolator; 265/75R16 Nitto TGs or 255/85R16 Truxs MTs; Cobra 75 WX ST cb; Alinco DR635 VHF/UHF ham radio; ham call sign license plates - VE7 EGC |
#3 (permalink) |
As soon as you get it fixed and clear the code, those VSC & TRAC lights will come off.
First thing you do: CHECK YOUR GAS CAP!
__________________
2002 T4R 4WD Onyx Black Sport with leather. |
#4 (permalink) |
Disconnect the battery for a bit, then connect again. See if that works before you take it to the shop or buy a scanner.
#5 (permalink) | |
Quote:
Just disconnecting the battery before you know your code won't help you one bit. Checking your gas cap to see if it is loose is a common issue with any OBD2 car when it is running great.
__________________
#6 (permalink) |
I had my 2nd-hand 4Runner Limited (97k) at the dealership for routine maintenance on 24-25 Aug., and today the same VSC off / VSC Trac / Check Engine sequence noted above appeared when my mother was driving it.
I called the dealer, and they said check the gas cap. As long as it drives OK, it is probably an erroneous evap fault, and that it will clear soon. I'm skeptical of that since when my Jetta faults, the check engine stays on until the code is cleared. (A host of Jetta owners drive with a check-engine light on. The problem is, I have moved to NJ and just got the car plated on 28 Aug, which means I have until 11 Sep to get in inspected, and NJ stupidly fails a car with a check engine light on (stupidly, because many cars spit out check engine lights for trivial reason; see my Jetta comment above). So, should I wait until Tues to see if the check engine light leaves, or should I take the truck in to get the code read and cleared? |
#7 (permalink) |
Like they said above, go to an Autozone, Checkers or a parts store with a scanner. You can get it done for free. Hopefully, it's just your cap. Half of the time, it's your O2 sensor(s).
__________________
2000 UZJ100 |
#8 (permalink) |
Guys, I've been having the same occurrence. Check engine light + VSC
My truck is a 2004 4runner, about 69k miles on it... I went to the dealership, and paid for the diagnostic check. I've attached a copy of their report. The truck pulled error code: P1056. When I spoke with shop tech, I was advised to replace the Bank 2 Sensor 2. So I did, check the attached pic. I ordered the part from Partznet.com (conicelli) and I also swapped out the stock battery, since I was also advised that the original had 20% full load capacity. I tossed in a Die-Hard North. And guess what, the check engine disappeared but I still have the VSC problem. But here is what I've noticed. When I start the car up, and have it in park, there is no VSC light on. However, as soon as I toss it into reverse, to pull out of the driveway, within 3 seconds, the VSC lights pop on, and stay on. I don't know what to do at this point. I was reading in TSB BR005-03 that the YAW sensor can easily be reset. Keep in mind that bulletin was for '03 4runners, of a particular VIN batch, with a YAW rate disfunction reading. Any ideas? I've done the autozone gig before, and it good for reading the error code, but how do you go about resetting it? At this point, maybe that is what it need? ![]() ![]() ![]()
#9 (permalink) |
You need what is called the "Zero Point Recalibration". Only the dealer can do it. Just pay the money and get it fixed so those lights stay off.
__________________
#10 (permalink) |
I was thinking the same thing, TSB BR005-03 is all about that.
Thanks. |
#11 (permalink) | |
Quote:
I used two paper clips, stretched out and one inserted into each of the appropriate pins on the DLC3 (OBDII) connector. I made sure they didn't touch, then simply squeezed them together a couple times to shunt (the word "short" usually implies a defective connection so I don't use it here) the pins and then follow the rest of the steps in the TSB. Simple! FYI. The TSB says, "with the engine off" This means with the key in the Run position, but not running. When the TSB says turn the ignition off, that means turn the key all the way to the off position. AFYI: TSC TRAC + TSC OFF + CEL = O2 sensor says bad cat. Either O2 sensor or Cat (read about this product: http://www.empirepao.com/sims.php ) TSC TRAC + TSC OFF (especially if they are off and come on as soon as you move the vehicle) = Zero Point Calibration (use the TSB instructions)
__________________
2004 4Runner 4.7 V8 5 speed Limited. Cellphone booster (powered, wireless, 3W), electronic brake controller, chains, aftermarket GPS/video, backup camera (not yet installed). |
| Tags |
| 2002, 4runner, battery, caps, check, clear, codes, disconnect, engine, gas, lights, toyota, trac, track, trouble, vsc |
