tps sensor ?
Old 06-23-2004, 02:23 PM
Gabe's Avatar
tps sensor ?
What are sure fire signs that your tps sensor is going out? I seem to have a problem where after my engine is warm, then I stop the engine for 5 minutes or more, the engine fires up at less than normal idle RPM's, I lose perhaps 2-3 hundred RPM. To get her back to normal I have to stomp the throttle a few time then it'l idle normally. This is a sporadic problem, never happens when I am running. (and yes I've done the throttle body cleaning and ran the techron and redline fuel injetor cleaner....). Where is the TPS anyways?(check my sig for my rig stats)
Old 06-23-2004, 02:59 PM
nigeltufnel3's Avatar
The tps is on the drivers side of the throttle body. It is a "flat lightbulb" shaped component that is about 2-3" long. One test to see if it is functioning properly is to insert a jumper wire (speaker wire, paper-clip, etc.) between the Te1 and E1 termials in the little grey "diagnosis" box. If the engine retards at all you've passed the test. This is at least how it works on a 22re. Hope it helps. Good luck.
Another though: I don't know, but your problem may be your thermostat. When I flushed my coolant, I think I may have done something to it, so it idled at varying speeds. I think the temperature wasn't registering right. I reset the computer and it fixed itself in a couple days. Just another thought.
Old 06-23-2004, 03:08 PM
Gabe's Avatar
good info-I did put a new thermastat a while ago right around when it started to do this. It was the cheap one too that didn't have the toggle valve like my stock one, I didn't think this would make a difference but I think I will go to toyota and get a new one...
Old 06-23-2004, 03:10 PM
radrex's Avatar
You can easily test the TPS with an OHM meter. I doubt that is your problem.
Try changing your Plugs/wires/distributor cap and rotor. Make sure the timing is dead on.
If that doesn't fix it - use your ohm meter to start testing the injectors.
You might also change the fuel filter.
Wait - I noticed you've modified your air box... Could you have screwed up the Air Temperature Sensor?? Hmmm..
Old 06-23-2004, 03:35 PM
Gabe's Avatar
nah, not the air box, doing it waaaay before the mod, changed fuel filter about 40k ago, new plugs about month ago--(again was doing rpm thing before)--but perhaps the wires. The cap and rotor are good but my wires are beat to @#$%! I kinda yanked the ends off last time I put the plugs in, but I was able to clamp them back together, I know others out there have done this...any recomendations for new wires?
Old 06-23-2004, 06:54 PM
radrex's Avatar
OEM Toyota WIres -- www.1sttoyotaparts.com $52.68
Well worth the price
Blamalam
03-12-2022 07:34 AM
Kreedy1
09-08-2015 06:33 PM
markf1
09-03-2015 01:23 AM
Blamalam
08-16-2015 12:29 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Quick Reply: tps sensor ?
