TPS Problems
Old 11-09-2011, 04:47 PM
cpizzle42's Avatar
TPS Problems
2002 tacoma supercharged, URD 7th injector kit.
Having electrical problems on the truck I am working on. With TPS plugged in the truck runs good, idles at 750RPM, BUT cuts power at 2500RPM.
With the TPS unplugged, the truck runs good. Although it idles high, and when you are at the bottom of the RPM range and punch the gas, it will hesitate bad, almost killing the motor.
Any ideas? Bad TPS?
Old 11-11-2011, 06:25 AM
Nelsonmd's Avatar
Sounds like a bad TPS to me. Mine would stop revving higher than about 2500 RPM's despite me flooring the accelerator (sounds like this is what yours is doing). I unplugged it an plugged it back in, and that temporarily fixed it, but it's fairly cheap so I replaced it anyway, havn't had any problems since.
Old 11-11-2011, 07:30 AM
BMcEL's Avatar
Good way to find out if the TPS is bad...TEST IT.
smthwsn357
12-04-2023 02:08 AM
Gone Fission
01-12-2023 10:34 AM
Sleaker
08-26-2020 06:03 AM
jetpilot
08-15-2015 06:48 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Quick Reply: TPS Problems
