Toyota paint touch up. - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 06-08-2003, 10:11 AM   #1
JGage's Avatar
Got a couple of chips in my paint now... and somebody with a red door decided to slap my door panel.
Has anyone tried the Toyota touch up paint sticks that they sell at the dealership ? Do they work well, easy to apply, and give an even coat ?
Regards,
JGage is offline   Reply With Quote
Old 06-08-2003, 12:11 PM   #2
kronicx's Avatar
Touch up sticks? Is that the same as just the touch up paint? Just want to make sure we're talking about the same product.
I got a tube of touch up paint. It matches very well, but it's not easy to make it match perfectly. The lid has a brush on the end to apply the paint, but for me, the chip was smaller than the brush, making the application difficult. Bob showed me a product that should make it match very well, it's called Langka. http://www.langka.com
It allows you to not have to apply the paint exactly, you can leave a little extra. This stuff will remove the extra, and should make the chip almost unnoticeable.
I definately think the touch up paint is worth the investment, it was under $10.
kronicx is offline   Reply With Quote
Old 06-08-2003, 12:52 PM   #3
JGage's Avatar
Thanks.. Yes, the touch up paint is what I meant.
Old 06-08-2003, 12:57 PM   #4
EDGE's Avatar
I used some touchup paint on the ES300, freakin car was a week old and their was a scratch down to the black plastic on the bumper behind the right tire, if the car any color other than silver it would have not been as bad, touch up paint was OK I see it but other don't
EDGE is offline   Reply With Quote
Old 06-08-2003, 01:00 PM   #5
Bighead's Avatar
Quote:
Instead of using the brush that comes with the paint use the end of a paper match. Pull one out of a book of matches and use the non-flame end (obviously). If that is still too big, a little trim with a razor blade will get it smaller. I will use at least one match per spot I am touching up. Any more than that and the match end gets too sloppy.
Bighead is offline   Reply With Quote
Old 06-08-2003, 01:22 PM   #6
JGage's Avatar
Good advice, thanks.
Old 06-09-2003, 04:45 AM   #7
Tacoma Dude's Avatar
This may be anal but I use electrical tape to trace the contours of the scratch (both sides) and then go at it with the touch up paint. Its worked pretty good so far.
Tacoma Dude is offline   Reply With Quote
Old 06-09-2003, 09:11 AM   #8
JGage's Avatar
That's not anal, that's what I was going to do originally.
Old 06-09-2003, 09:52 AM   #9
rimpainter.com's Avatar
I have used the "new" touch-up pens found at the dealer, and I am very pleased with the results. The pen has a fine tip ball at the end, and really gets paint into the heart of the scratch.
I prefer this method to the traditional brush type touch-up.
rimpainter.com is offline   Reply With Quote
Old 06-09-2003, 02:34 PM   #10
whoa!
Didn't know they had pens.
You folks in AZ must be holding out on us...
Old 06-09-2003, 09:30 PM   #11
Vato Loco's Avatar
How much do those touch up pens go for?
Vato Loco is offline   Reply With Quote
Old 06-10-2003, 07:15 AM   #12
Quote:
About $5 at the dealer.
RedRunner_87's aka "Operation Mall Crawler" Build Thread RedRunner_87 95.5-2004 Tacomas & 96-2002 4Runners (Build-Up Section) 60 01-14-2017 05:16 PM
White tire letters in, or white letters out? Scenic WonderRunner Off Topic Talk 36 03-03-2016 08:37 PM
20R Distributor Differences 1979-1980 msane99 Pre 84 Trucks 6 07-11-2015 09:08 PM
Radiator leak. Now where to? (2000 v6) Avenged 95.5-2004 Tacomas & 96-2002 4Runners 4 07-09-2015 08:55 AM
1984 extra cab build up toyoda8488 84-85 Trucks & 4Runners (Build-Up Section) 2 07-05-2015 11:18 PM
Tags
2003, 2007, 99, cruiser, gray, land, paint, pen, purple, royal, sticks, tacoma, tape, touch, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
