Toyota e-locker gear ratio
Is the Toyota e-locker independent of the gear ratio? What I mean is can an e-locker be transferred to another diff that has a different gear ratio without causing any problem relating to the differing gear ratios?
Or do I need to change also the gear ratio?
Thanks!
Thanks!
The e-locker should be compatable with other gear ratios, maybe not all of them, but I'll go out on a limb and say most of them. The bigger issue with it is the diff housing is different and takes some fairly major modification to fit into a non-elocker axle. Unless you're pretty handy with metal fabrication, most guys swap the whole axle (drum to drum).
you can swap whatever ratio you want on the elocker (with exception of the factory 4.88's i think). yes, if the ratio that the elocked 3rd is going on doesnt match whatevers on the third, it has to be regeared. id be willing to bet most elocked 3rds are 4.30 & 4.10. as mt goat stated, the stock axle housing has to be modified.
Here's some info on modifing the axle housing:
http://www.4x4wire.com/toyota/tech/electric_locker/
i have a quick ? i have an 85 runner and i wanna put elockers front and back i have them already but both with different ring and pinion sizes one of them has a 41 tooth ring and 11 tooth pinion the second has a 43 tooth ring and a 10 tooth pinion i dont have the vin number of the vehicle it came off of and dont know what the ratios are? i wanna throw one in the back and just run the rear elocker tell i do my lift but i currently am running 4:10 also does the pinion flange bolt str8 up to the driveline or does that require modification?? guess that wasnt such a quick ?
FS[SouthCent]: Toyota Trail Gear 5.29 Ring and pinion x2 NEW
YotaLogic
12
11-17-2015 06:27 AM
