Towing (2) Atv's, OD on or off????
Old 03-11-2005, 11:46 AM
joshd's Avatar
I always thought with automatics that when you tow anything to do it with the overdrive off, but with my 2 sport atv's (about 350lbs each) and my two place snowmobile tilt trailer (mayby 500 lbs) would you even bother to turn it off? Let me know what I should do. Thanks Josh
Oh btw, it is a 98 limited 3.4 auto.
Old 03-11-2005, 11:48 AM
Flamedx4's Avatar
Depends on how its doing. If it keeps hunting up and down between 3rd and 4th, turn the OD off. Usually on hills and such. If it's happy, leave it alone.
Old 03-11-2005, 11:49 AM
joshd's Avatar
So, it is not going to overheat the tranny or anything? I guess that is what I am most concerned about.
Old 03-11-2005, 12:03 PM
kevin444's Avatar
Dont stress the tranny od off.
Old 03-11-2005, 12:07 PM
joshd's Avatar
Will I have any problems cruising about 75-80 mph with the o.d. off?
Old 03-11-2005, 12:24 PM
rimpainter.com's Avatar
Just MPG.
Old 03-11-2005, 12:36 PM
AgRunner06's Avatar
Your tranny is only going to overheat if it is constantly shifting between 3rd and 4th. If you can drive with OD on and it will stay in 4th the majority of the time, then you should be fine. I would think that you will be able to do it. That really isn't very much weight you are going have behind your rig. Just give it a shot. If it keeps downshifting then turn OD off; if not, leave it on.
:bounce2:
Old 03-11-2005, 12:45 PM
joshd's Avatar
Thanks Guys, This is the 1st slushbox I have owned, so I am kinda a newbe to the autos. I know that it is not that much weight, but I had to get the runner because my taco w/ 5 speed, 33's and not regeared has to be in 3rd floored to even have a chance to make it up hills pulling that trailer.
Old 03-11-2005, 01:44 PM
Rick F.'s Avatar
Location: Far western Kentucky (transplanted from central PA)
When I tow, I typically turn the OD off unless I'm on the highway and can maintain a steady, fast clip. Like Flamedx4 said, if it's not hunting (or if you're not "lugging" the engine) then leave it on. I just don't like to be turning low revs with that kind of load (I sometimes tow 3000 lbs. +) on the engine.
Brodetski
09-30-2015 11:50 PM
Cycles
09-29-2015 06:37 AM
Odin
09-26-2015 06:56 PM
toyhaulert100
09-24-2015 07:55 PM
pickle6415
09-10-2015 10:57 AM
Quick Reply: Towing (2) Atv's, OD on or off????
