| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
| View Poll Results: Should I buy a tow strap with: | |||
| "loop" ends |
69 | 88.46% |
| "hook" ends |
9 | 11.54% |
| Voters: 78. You may not vote on this poll | |||
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Tow straps
__________________
-Noel- 2002 Tacoma Double Cab Impulse Red w/ color keyed package...2nd generation supercharger...TRD off road package...TRD boost guage...TRD tranny cooler...Borla exhaust...Speed Liner spray in bed liner Last edited by tomus1000; 04-16-2003 at 10:18 PM. |
#2 (permalink) |
If a strap breaks with a loop end, there's no risk of injury. The straps with hooks can become deadly projectiles. The hook ends are designed for towing, not a recovery strap for a stuck vehicle.
__________________
Gibby 1994 4Runnner 6" lift: Leaf spring conversion rear, SAS front. 1180 Ramp score. DANA 60s with ARB lockers 39x13.50 IROKs SBC 350, NP203 - NP205 Allpro bumpers and rock sliders. www.faithwheelers.com |
#3 (permalink) |
Hook ends are "tow" straps, loop ends are "snatch" straps. Never use a strap with hooks for recovery.
__________________
"It's one great big dysfunctional family that now has to split up and spread dysfunctionality around the greater world," Bill Stainton on the breakup of the cast of "Almost Live!" |
#4 (permalink) |
Both.
Use the one w/hooks for light vehicles and such and for towing, but never for a vehicle that's stuck bad or the hooks could become a weapon. This is good if someone is just a little stuck and could use a pull/push to get the tires back on the ground or whatever. The ones with hooks, in this case, are fast & easy to use and they normally only need to be moved a meter or two. It's also good if they don't have D-ring shackles or open tow hooks. I've pulled a few stuck cars out of deep snow and they only weigh about 3000 lbs. at most. A recovery strap would have been useless as these cars don't come w/open tow hooks. Recovery strap for the obvious: serious recovery. If they are "seriously" stuck, they should have thought they may get in that position and have open tow hooks or D-ring shackles. If not, they should have thought ahead... I bring a tow strap (hooks), recovery strap (no hook) and spare D-ring shackle for those who have nothing but frame holes.
__________________
1997 4Runner Ltd. Bilstein shocks, rear E-locker & riding on 32s. Mods Pics Tech articles, write-ups & more are available on my website. http://www.hboss.net/4runner Last edited by HBoss; 04-16-2003 at 10:49 PM. |
#5 (permalink) |
When you guys use recovery straps with loops at the end, and the vehicle doesn't have a "tow hook" on the front or back, how do you connect it to the stuck vehicle? Basically, I'm asking if you make some sort of slip knot, or what? Just curious. Thanks-
CTB
__________________
1995 4Runner V6 4x4 |
#6 (permalink) |
I'm getting one with loop ends soon. Definitely before EC4RJ. It will make a nice addition to my winchless, open diffed, AT tire wonder.
__________________
UZswap.com A site dedicated to sharing info for swapping the Toyota/ Lexus UZ (V8) engines into Toyota Trucks and 4Runners. My 4Runner 1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys, low lift, hacked fenders, tubbed firewall, custom armor TOOLandFAB.com A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion Last edited by Cebby; 04-17-2003 at 06:13 AM. |
#7 (permalink) |
I vote no hooks. Unless like the others said it is strictly for short towing and not recovery snatching.
__________________
-J.A. 2007 4Runner Sport 1999 4Runner Highlander My Runners 4Runner Topsites 4Runner Diecasts |
#8 (permalink) | |
Quote:
__________________
#9 (permalink) | |
Quote:
If it's you without tow hooks, get some! They are cheap and easy to install.
__________________
#10 (permalink) | |
Quote:
I think its time for me to get some non-hooked recovery straps!
__________________
www.rimpainter.com Get your O Gasket Mod Here! My SC'd 4Runner's Profile My YouTube vids |
#11 (permalink) | |
Quote:
__________________
#12 (permalink) | |
Quote:
__________________
#13 (permalink) | |
Quote:
__________________
#14 (permalink) |
Alright, now a question about tow hooks...
I just have the single factory tow hook in the front, and nothing in the rear (except for the factory hitch). Should I try installing another hook on the front, as well as one or two on the back, or should my current setup be sufficient? If so, where should I look to purchase the hooks, and where should they be mounted? I haven't looked to see if there are any good stock mounting locations yet, sorry. Thanks for the info fellas- CTB
__________________
#15 (permalink) |
There are a couple of small holes in the back that you could put a shackle through, or the big hoops under the rad.
Rear Passenger Rear Driver (above exhaust pipe - sorry bad pic) Front Passenger Front Driver
__________________
UZswap.com A site dedicated to sharing info for swapping the Toyota/ Lexus UZ (V8) engines into Toyota Trucks and 4Runners. My 4Runner 1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys, low lift, hacked fenders, tubbed firewall, custom armor TOOLandFAB.com A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion |
#16 (permalink) |
Hey Cebby,
So, you think a shackle would work in that hole in the "rear passenger" picture you posted about? Do you think it would matter if the shackle had any play in it, or would the center shaft of the shackle need to fit through that hole really tightly? (haha, really sorry if that sounds like sexual innuendo, not meant to )
__________________
#17 (permalink) | |
Co-Founder/Administrator
Staff
Quote:
It looks by Cebby's last two pics you could use a D ring shackle on the front where those holes are, but I am not sure of the strength of the mounting brackets. You certainly don't want a shackle to break at that mounting point and end up becoming a deadly projectile.
__________________
Corey 2007 FJ Cruiser Built for 4wheelin', expedition, camping, and overlanding use PNW FJ Cruisers ☺ Detailing 101 ☺ Join Topsites ☺ Muffler Comparisons ☺ Maggiolinas In The Wild FJ Cruiser Buildup ☺ New Roof Top Tent ☺ Video Of My Penthouse Part II ☺ Rehinge Your ARB/Engel Fridge Blog About Roof Top Tents ☺ FJC Magazines Online Review Of My Tent ☺ 2009 Specialized Rockhopper Pro |
#18 (permalink) |
The front holes are a separate bolt-on piece. They bolt into the frame with a 1/2" equivalent bolt. This is also how the factory tow hook is on also though.
The rear tabs are welded on. Not sure of the hole size in the back, I'm in a suit and don't want to roll around on the ground to measure it. ![]() The way that plate hangs down in the back, there is probably a chance it might bend if the tugging gets violent, although is is about 1/4" thick, runs up the side of the frame rail and has a nice bead holding it on. I think the shackle "should" be snug, but it probably isn't critical. I doubt there is possibility that it would break. I'm ordering some shackels soon. If that hole is too big, I'm going to weld an insert into it to beef it up cause I want to leave my shackle on (without rattling) Now that it's nice out, I can finally break out the CTB, if it's too loose, they have pills for that now...
__________________
#19 (permalink) |
Staff
Cebby, if you want some shackles that will stay nice and not need paint, check out "Off Road Only" in the Vendor section.
They have nice stainless steel ones that are not much more than a standard one. |
#20 (permalink) | |
Quote:
Corey, how often do you need to paint your shackles?
__________________
#21 (permalink) |
Staff
Eh, ouch
![]() I did not realize the ss ones were so much. I have only painted the front ones one time. It holds up pretty good. Makes it easy to spot me 1/2 mile away
#22 (permalink) |
I recently had this discussion with the guys about hooks or straps and we came to the same conclusion so i bought some looped straps but it's good to hear it backed up by the experts here.
__________________
Chris W 1995 4runner www.toontoys.ca www.maketradefair.com |
#23 (permalink) |
Please, please, please do not use anything metal during a recovery. That includes tow straps with metal hooks.
As others mentioned, those are for towing a disabled vehicle on road where there is very little chance of a shock loading the strap. Most quality TOW straps even have a off colored thread that runs through them to show when the strap has been shock loaded and is no longer suitable for use. A "Recovery" strap will always have sewn in eyes. During my Trail 101 classes I show examples of both and we talk about when each is appropriate. But I think it's this picture that I pass around that illustrates it best. This photo is of what happens when a strap with a metal hook fails. Now imagine that was the back window or a person.
__________________
-Rob Slightly Modified 2001 Tacoma - WATRD.COM WATTORA is becoming NWToys! Tread Lightly! certified Tread Trainer Search 100+ Toyota tech sites, including this one: Toyota Tech Search |
#24 (permalink) | |
Quote:
Ya Ya, go ahead and rub it a little more! Hey Cebby, I will probably run out to my rig later this afternoon and check out the diameter of those rear holes, and see about ordering up a shackle or two for them. I'll let you know what i measure them at.
__________________
#25 (permalink) |
<There are a couple of small holes in the back that you could put a shackle through, or the big hoops under the rad.>
Cebby, those are "tie downs" for when the rig is transported on a flatbed or the like. They will tear and eventually fail if they are used for recovery. They should never be used for yanking or being yanked. In some clubs, usually the more harcore ones, you may not even have those on your rig so they don't get used for that purpose. The best bet is replace those eyes with proper devices designed specifically for recovery. Shackels in a receiver, hooks, whatever. (just call me "Safety Guy" today, but I have seen some pretty horendous injuries due to unsafe recovery techniques over the years and the fine folks here are way too nice to let those things happen to them)
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Tow capacity on 2004 v8 2wheel drive with tow package | coopma | 03+ 4Runner/GX470, & 05+ Tacomas | 26 | 10-05-2007 05:05 AM |
| KILLER deal on ProComp tow straps | 4x4taco | Offroad Tech | 83 | 12-09-2004 06:40 PM |
| Limiting Straps | Alstaz | 95.5-2004 Tacomas & 96-2002 4Runners | 13 | 03-02-2004 05:58 PM |
| Tow Hook Replacement with Tow Jaw? | Denk | Offroad Tech | 7 | 10-01-2003 11:44 AM |
