Torsion bar problems...
Ok, I just completed my lift and am running into some problems adjusting the height. Ground to fender on the driver side is 40" and 39" on the passenger side. Problem is the passenger side won't get any higher, it's as high as it'll go. Besides lowering the other side are there any solutions??? I like the looks of the driver side better, it matches the rear almost exactly. Thanks for the help guys.
Go top of the rim to fender, Make it easier to tell where you are at with your height. Might be maxed out, might be hung on adjuster nut. They do get stuck, take it from someone who had to break both bolts to get them apart. Well both bolts and a 22m wrench that had a lifetime warrenty. That hurts, fyi
Ok, thanks.
But the bolt that you twist to adjust height looks like it's at it's max. It's just going into the rubber piece. There's not a lot of thread left either. It seems that both bolts are different lengths. Should I just get 2 new bolts and nuts? (haha, just sounds kinda funny)
Originally Posted by WSU4runner
Ok, thanks.
Originally Posted by KevyWevy
hey guys, could it be his shocks if they're hyper extended, then they wont let the control arms drop any more right?
Could also have something to do with the gas tank being on the passenger side. My truck has never sat level. The passenger side is always lower, and even more noticeable when the tank is full.
choppe777
05-16-2016 08:00 AM
WTB[PacNorWest]: Old Man Emu Torison Bars
A2theK
10-14-2015 07:10 AM
FS[SouthEast]: Brand new 26 mm. Downey torsion bars
HiLuxer
09-09-2015 02:43 PM
