Torque Converter Lockup - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-16-2005, 04:19 PM   #1 (permalink)
93ToyKid's Avatar
Send a message via AIM to 93ToyKid
Is there a way to keep the torque converter on my 89 3.0 from locking up? On the freeway, if it were just in overdrive with no lockup, it would be at the perfect RPM. (I have 4.88s and 37s). Is there a wire you can unplug from the tranny, or a brake relay that tells it to unlock? Also, would this produce too much heat, since there will be slippage when on the highway with it unlocked? Thanks guys, just trying to find a way to help my faithful 'ol 3.0 get on down the road...........
93ToyKid is offline
Old 03-16-2005, 04:20 PM   #2 (permalink)
93ToyKid's Avatar
Edit: I just thought of something even better. Is there any way to have it lock up in third and keep overdrive off? That would be ideal. Thanks!
93ToyKid is offline
Old 03-16-2005, 05:29 PM   #3 (permalink)
SD70MAC's Avatar
I would say the best thing to do is get a different torque converter. One with a higher stall speed should solve your problem. I'm going to change mine out for one with a different stall speed because I can't maintain highway speed when it shifts into OD, I have to keep OD off just to maintain 75 miles per hour. Changing the stall speed will change the RPM that the TC reaches coupling phase/rotary flow (lockup). Check around online for different manufacturers and see what they have for your truck, or call them and explain your situation and they should be able to hook you up.
__________________
FOR SALE: 89 4Runner - 3.0. BFG All-Terrain T/As
D&RGW - "Mainline Through The Rockies, Not Around Them"
SD70MAC is offline
Old 03-16-2005, 05:31 PM   #4 (permalink)
toyotaoffroad91's Avatar
to words "re gear"
toyotaoffroad91 is offline
Old 03-16-2005, 05:46 PM   #5 (permalink)
ChickenLover's Avatar
Quote:
You can lock the TC up in third by simply turning o/d off. Next time you are accelerating in third, click the o/d button off and you'll feel the tc lock up and the rpms will decrease by about 500.
__________________
95 4Runner, 3VZE , 141k, 4WD, Auto. (Head gaskets replaced at 106k)
ChickenLover is offline
Old 03-16-2005, 07:30 PM   #6 (permalink)
93ToyKid's Avatar
Thanks for the replies! Yes re-gearing would be great, but the gears are brand new, as my cousin installed them with detroits front and back right before we bought the truck. He put the 4.88s in it because then he had the option of running anywhere between a 33-37. It's not as dead as you would think it would be. If I can get the lockup thing to work as chickenlover said, it'll do just fine. I probably would have put 5.29s in it, but even then it probably wouldn't pull overdrive on anything except the highway, so it would be way overreving around town. Right now it's about right. O/D is only used on the highway.
93ToyKid is offline
Old 03-16-2005, 07:36 PM   #7 (permalink)
Jeffires's Avatar
Send a message via AIM to Jeffires
On GM its easy- a buddy of mine has a switch in the console of his '85 442 that keeps it locked or unlocked whenever he decides. For my truck (only running 31x10.5), I would like to fix mine to where I can force it to stay locked- coming unlocked on slight hills brings up RPMs and is not necessary. If it would stay locked, it seems like I would just loose some speed rather than unlocking....
__________________
-Jeff-
'91 4WD P/U 3VZE A340H , 197K
K&N air ] Optima ] Flex-a-Lite fan ] FloPro exhaust ] ISR Mod ] Warn M8000 ] Powertrax lockers ] Swaybar Discos ] KC Lighting ] Premier MP3 - Pioneer highs/mids - RF DVC 12/ RF 360a² ] Garmin GPSMap60C
Photo Album
MySpace
La Nouvelle-Orléans
'da Ragin Cajun
Jeffires is offline
Old 03-16-2005, 07:44 PM   #8 (permalink)
93ToyKid's Avatar
Well we had thought about rigging up a switch just like you're talking about. Anyone know of any pros/cons to that?
93ToyKid is offline
Old 03-16-2005, 07:50 PM   #9 (permalink)
Jeffires's Avatar
I don't see what would be bad- I've driven his 442 and you can leave it unlocked or force voltage to the switch and lock it up manually in any gear, when you slow down to a low speed for that gear or punch it, it acts like a manual transmission (when forced locked). I don't know how good or bad it is for the transmission, as I haven't worked on auto's before.
__________________
-Jeff-
Photo Album
MySpace
La Nouvelle-Orléans
'da Ragin Cajun
Jeffires is offline
Old 03-17-2005, 05:50 AM   #10 (permalink)
MTL_4runner's Avatar
Send a message via AIM to MTL_4runner
It builds up alot of heat on the highway if you don't allow the converter to lock up.....not to mention you are eating up gas mileage too. If you have an OD button, just use that instead. If you don't, it would be far better to regear properly for the size tires you are running.
__________________
- Jamie
1996 4Runner SR5 4X4 Auto
Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift
Best OBD II scan tool I have used!.
.....and I am AMERICAN!
MTL_4runner is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Torque Converter tampabayota General Vehicle Related Topics (Non Year Related) 8 03-12-2007 03:12 PM
Could this be the torque converter? Del General Vehicle Related Topics (Non Year Related) 1 01-01-2006 03:17 PM
torque converter lockup problems toyotaoffroad91 95.5-2004 Tacomas & 96-2002 4Runners 0 08-12-2005 09:37 PM
No converter lockup quick2300 95.5-2004 Tacomas & 96-2002 4Runners 17 12-20-2004 04:28 AM
I want to manually work the Torque converter lockup williemon 95.5-2004 Tacomas & 96-2002 4Runners 6 07-16-2004 07:32 AM
2009 InternetBrands, Inc.
