Tokico shocks
Old 12-18-2007, 09:00 AM
penangtoy's Avatar
Tokico shocks
My apologies for my Ignorance Does tokico only make one type or one length of blue green shocks /tokico trekmaster RT? I am trying to setup my 99 4runner with OME 3" Lift Front Coil Kit
Old 12-18-2007, 09:16 AM
Nate08's Avatar
Yes. Talk to Steve at Sonoran Steel. If you get some that aren't from him, be sure to use your stock nut, not the one supplied.
Old 12-18-2007, 09:17 AM
frodin1's Avatar
AJUSA has them for $119 for the fronts
Old 12-18-2007, 09:24 AM
Nate08's Avatar
Be sure to use your stock nuts.
Old 12-18-2007, 09:25 AM
penangtoy's Avatar
. If you get some that aren't from him, be sure to use your stock nut, not the one supplied.[/QUOTE]
do i need to modify the shock?
Old 12-18-2007, 09:41 AM
Nate08's Avatar
Nope. The stock nut will thread down perfectly on the Tokico Shock.
Old 12-18-2007, 10:52 AM
Bighead's Avatar
FYI...Steve does not sell the shocks separately. He only sells them with a complete lift kit.
Old 12-18-2007, 01:30 PM
Nate08's Avatar
Tokico Trek > Master R/T Green Shocks:
96-02 4Runner Front: $64.50 each
96-02 4Runner Rear: $46.25 each
* Sold in a set of 4 only: $221.50 *
Not according to him.
Old 12-18-2007, 01:47 PM
Bighead's Avatar
I stand corrected. I did not realize he started selling them outside of the kits.
Old 12-18-2007, 02:01 PM
penangtoy's Avatar
I got them from AJUSA 119 plus tax but free shipping thanks for all your input
Old 12-18-2007, 02:48 PM
Guest
seanz0rz's Avatar
yea, use your stock nut, OR go buy new hardware from an autoparts store. you want the highest grade nut you can find, take the shock with you and have them match up a nut.
the ones supplied with the green shocks WILL fail! i found this out the hard way!
Old 12-18-2007, 02:57 PM
penangtoy's Avatar
what size is the stock nut? also is this stock nut you are referring to on my rig now. Thanks for the advice
Old 12-18-2007, 03:10 PM
Guest
seanz0rz's Avatar
shock nut is 12x1.25 or 12x1.5 (god i just dont remember, i think its the former) it is the same size for both stock shocks, and the tokico's (other brands may vary)
tokico included a 1/2" nut that fit well enough to hold the spring in compression, but blew off when they were compressed fully and then suddenly released.
a bit off topic, but i thought steve stopped selling the green shocks? or was that only for the SS 1.x kits?
Old 12-21-2007, 03:20 PM
icerunner's Avatar
Sorensen steel all the way, I just installed 4 new tokico shocks and they work great.
Good luck and happy trails
ladybugRC
458
08-21-2020 10:41 AM
ZGjethro
06-07-2017 11:04 PM
dirk89
10-01-2015 05:15 PM
ktm192k
10-01-2015 08:47 AM
hiluxinargentina
09-30-2015 05:51 PM
Quick Reply: Tokico shocks
