Tires sticking out
Old 05-07-2004, 09:02 PM
GrnMtn4runner's Avatar
Tires sticking out
looked at my 2nd gen 4runner today and realized that the drivers side tires seem to stick out more than passenger side by a good 1/2". any ideas on what this might be? the truck still drives normal
Old 05-07-2004, 09:19 PM
doink's Avatar
is it in the front or the rear? or both?
Old 05-08-2004, 09:20 AM
both front and rear
Old 05-08-2004, 09:21 AM
also noticed it after i put new tires on and had been stuck for 15 minutes with the rear fully articulated
Old 05-08-2004, 06:52 PM
breakerfalls's Avatar
Were all the tires bought at the same time by you? Perhaps you ended up with two 10.5s and two 11.5s or something crazy.
The only things I know of that would allow for extra space would be wider tires or wheel spacers. Anything beyond that is new to me.
Old 05-08-2004, 10:12 PM
anthony1's Avatar
Is this all stock truck or do you have body lift on it?
With the rear pan hard rod, if you have factory sag then the rear could do that.
Old 05-09-2004, 12:09 PM
yeah its all stock. im working on getting some leveling springs from my brother and we'll see were it stands after that thanks though
Old 05-09-2004, 12:55 PM
86toyota's Avatar
My 92 4x4 p.u. is the same way. I didn't notice it with the stock tires, until I put on the 32's on 8" rims. Driver side sticks out at least an 3/4" more than passenger side. So I switched tires from one side to the other, same results. Guess it's normal. I have no lift also.
Old 05-09-2004, 05:01 PM
934rnr's Avatar
Body mounts can shift too if they aren't tight. It is possible if the body shifted over while you had it articulated.. Try articulating it the opposite direction and see what happens.
I would look at doing a small body-lift on it then you can get everything lined up with new hardware.
Old 05-09-2004, 05:29 PM
Fink's Avatar
I agree, sounds like a good excuse to get a lift my friend
Fink
bfmcelroy
08-18-2015 06:42 AM
priest16
15
08-06-2015 07:43 AM
Luvmeye22re
08-04-2015 03:53 PM
Cabell
07-24-2015 12:14 PM
Quick Reply: Tires sticking out
