Tire selection with OME 881/890
Old 09-10-2015, 06:44 AM
Swampwalker's Avatar
Question Tire selection with OME 881/890
So I lifted my 98 on OME 881/890 springs back in 10' and have been using stockish type tires since then. The outer edges of the tires have worn down quite a bit (presumably because they are fairly skinny and I hit corners too hard).
So I need some new tires and don't know where to start, most of the thinking I have done in terms of tires has centered around 18x245x40 type tires for my other vehicle which is a whole other game.
I mostly use my 3rd gen in the winter here in WY when my fast car is not so fun. I also get out on jeep trails between here and Utah in the summer and spend significant time on dirt county roads. Its a bit of a beater with 250k dings/rust/peeling clearcoat on top so I don't want to dump a huge sum into tires.
So I'm thinking I want something wider than stock but what tread-width/profile/load would you guys with experience recommend... or even specific tire recommendations.
Old 09-18-2015, 11:49 AM
ttt
ttt
Old 10-08-2015, 09:13 AM
4Runnin2000's Avatar
Originally Posted by Swampwalker
ttt
ttt
I am running 265/75/16 on mine. Any smaller and the lift would look a little weird. I have the 881 and 890 with bilstein 5100s around. Front are bumped up to second notch for abkut 3 inches total. I have seen a lot of guys running 285/75/16 but you may need a 1 inch body lift to prevent rubbing. Others say they don't rub without the body lift. So I guess it depends in the tire. Maybe someone else will chime in. But I would just Google ome 881 890 tires 3rd gen 4runner. You will see a lot of answers. Mainly on t4r.org. here's a pic of mine. I think when it comes time I will just go with a mud terrains and rims with a different offset to get me more flush. I like not worrying about rubbing.
Old 10-11-2015, 09:31 PM
SharpStick's Avatar
17" option...
I run a 275/70/17 Goodyear MT/R Kevlar with my OME 891s in back (Tundra 5100s in front). It's a narrower tire than some folks use and it doesn't get the best floatations on sand, but it's killer for narrow trails.
STICK
Old 10-12-2015, 09:17 AM
Thanks for the info guys, I currently have 245/75/16 tires on it that it came with 6 years ago (from my dad...) and they are wayyy too skinny.
No real sand around here, gravel and rock crawling on jeep trails mostly.
I guess I'll shop around in the 275/70/16 size.
Edit: Maybe these?
Amazon.com: Yokohama Geolandar A/T-S On/Off-Road Tire - 275/70R16 114S: Automotive Amazon.com: Yokohama Geolandar A/T-S On/Off-Road Tire - 275/70R16 114S: Automotive
Old 10-12-2015, 09:49 AM
[QUOTE=Swampwalker;52292887]Thanks for the info guys, I currently have 245/75/16 tires on it that it came with 6 years ago (from my dad...) and they are wayyy too skinny.
Edit: Maybe these? [url="http://www.amazon.com/Yokohama-Geolandar-T-S-Off-Road-Tire/dp/B004QL6Z9E/ref=sr_1_13?s=automotive&ie=UTF8&qid=1444670676&sr =1-13&keywords=Yokohama+Geolandar+A%2FT-S"]Amazon.com: Yokohama Geolandar A/T-S On/Off-Road Tire -
I don't have any experience with the geolanders. Tou could go to tirerack.Com and check out the reviews on them and all other tires. Good site to compare tires!
nvdesertrunner
05-11-2020 08:18 PM
39 Thieves
01-06-2017 01:08 PM
JookUpVandetti
7
09-10-2015 08:56 AM
Gio8
08-27-2015 12:14 PM
Luvmeye22re
08-04-2015 03:53 PM
Quick Reply: Tire selection with OME 881/890
