Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Tint removal tip Maybe
I was removing the20 plus year old tint off my bug. I was using one off those straight razorblabes with the holder . The flatlooking one you slide in and out with your thumb. It kept popping loose and sliding in so i took the straight razor blade out and put one of the boxcutter type,angled on both ends. The angles held it in place and locked down on it self. I could put all my pressure behind it and it never slipped in the holder. I did 4 windows in the time it took me to do the back window. ( i also kept it wet with cleaner) But the holder really helped. Hope this helps if anybody has that nightmare job of removing tint, it made it really easy.
__________________
1997 4runner. stock for now just got it 1999 z71, intake ,285bfgs,with ford keys,hypertech 1974 baja bug 2110cc dual weber 40s,rancho tranny www.lubedealer.com/dbcox ZO#1568374 |
| Sponsored Links |
#2 (permalink) |
I used a steam cleaner I bought at walmart for 50 bucks, then returned. Took me all of an hour to do an entire car.
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks. Be polite. Be professional. But, have a plan to kill everyone you meet. |
#3 (permalink) |
yep, i've had to take tint off of many a car, it's a pain. be especially careful of the back windows with rear defrost if you're using a razor blade! i use the razor blade to get it started and then pull as much off as possible by hand. then the worst part is getting all the glue off
the best way i've found to do that is saturate the glue with a solvent (i've used Acrysol and if you're VERY careful you can use Thinner too) and then scrape it off with the blade. make sure you either wear a ventilator mask or have lots of air flow otherwise it's brain cell death, or straight up death. on the rear defrost sections, i've done the same saturation of solvent but instead of a razor blade, i've used #0000 steel wool, it takes the adhesive off but doesn't harm the defrost strips. just a couple other tips i've learned over the years. ![]()
__________________
The PATYWGN: 1998 4Runner Desert Dune Pearl. PATYWGN show-off thread PATYWGN on Cardomain Pattycakes77 on Myspace! let me be your friend... please? 1985 Toyota 4runner 22RE 5-speed SFA - For Sale :( |
#4 (permalink) |
Acetone wont harm the defroster strips and works really good at removing glue, as does denatured alky.
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| tint removal? | livelarg | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 11-14-2005 05:55 PM |
| 2nd gen rear shock removal tip... | nrgetic99 | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 10-24-2005 06:13 AM |
| Tint Removal | lanai | 95.5-2004 Tacomas & 96-2002 4Runners | 9 | 03-24-2005 09:41 PM |
| To tint or not to tint....that is the question. | momo.75 | 95.5-2004 Tacomas & 96-2002 4Runners | 51 | 03-15-2003 09:58 AM |
| Tint | AgRunner06 | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 12-29-2002 06:54 PM |
