| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Timying
#2 (permalink) |
That's because you can't, the ECU controls the timing.
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! |
#3 (permalink) |
so would i half to take it to the dealer or a auto shop to get it done?
#4 (permalink) | |
Quote:
You can't adjust the ignition timing, period.
__________________
#5 (permalink) |
Why do you need to adjust it?
__________________
'99 SR5 Sport - Desert Dune: AirRaid MIT, OEM Air Filter, Toyo 265/75/16 ATs, Deckplate, PP Springs and Bilsteins, Cheapo nerf bars, Injector replacement impending |
#6 (permalink) |
i entered a rev off at school and came in 3rd and after that it back fires sometimes when i shift from 3rd to 4th and my dad said that it was the timing i don't know if he is right or wrong what do yall think it is.
#7 (permalink) |
WTF is a rev off? Do you just sit there and rev your engine?
__________________
Alan 1996 Supercharged 4Runner Limited Hi Altitude 4Lo A 4WD club for Colorado and surrounding states |
#8 (permalink) |
I was wondering the same thing....
So you basically started out with the truck running fine, entered this rev-off and now it backfires under load? and how's the idle? Sounds more like you might have slipped a tooth or two on the timing belt. You also could have burnt a valve or two, but you'd need to do a compression check.
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! Last edited by MTL_4runner; 03-02-2007 at 09:36 AM. |
#9 (permalink) |
They must just sit there and tach em up, just till the valves float, which is right before the the block becomes windowed?
__________________
99 4Runner, 3.4, 5 spd., Manually shifted E-Locker, 4:30 gears, 285/75/16 MTR's, Airbox mod through the bottom of the inner fender. |
#10 (permalink) | |
Quote:
And a rev off ehh??? wonder what thats like... Do you guys see who can hold it at red line the longest or what?
__________________
96 4Runner SR5 S/C - 03' Tacoma coils 3'' Toytec Spacer lift with 1'' Diff Drop. 3 1/2'' Downey Rear lift Coil Springs. 285/75R/16 Goodyear MT/R. |
#11 (permalink) |
I guess your name is fitting. Who revs the crap out of a 4 banger truck? lol
Rob
__________________
1988 Xtra Cab Pickup ('94 22RE; 4x4; 5spd) Rancho lift w/ 33x12.5x15 tires & 5.29s |
#12 (permalink) | |
Quote:
.......conjures up quite the mental image doesn't it?!
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! Last edited by MTL_4runner; 03-02-2007 at 09:49 AM. |
#13 (permalink) | |
Quote:
You mean 'Timmying'?
__________________
95 4Runner, 3VZE , 141k, 4WD, Auto. (Head gaskets replaced at 106k) |
#14 (permalink) |
![]() Wow, what a great audience.
__________________
#15 (permalink) |
It is possible to at least check the timing to see if its off. Do you have a haynes manual? It tells you step by step in there...
I have one so if nec. I can scan the pages up for you to see. Like MTL_Runner said...it is possible you slipped a tooth, I'd lean more towards the burning of the valves or something if its backfiring though. For the record...you have a timing chain...not a belt. |
#16 (permalink) |
[/quote] Do you guys see who can hold it at red line the longest or what?[/quote]
Thats about all you half to do to win and i also found that the crack in the exhaust manifold i welded when i first got the truck. it has re cracked around the weld and all the way around. |
#17 (permalink) |
Honestly, whats the point of the "Rev Off" ???? See who spends most money repairing afterwards?
Edit: What does the winner get?
__________________
96 4Runner SR5 S/C - 03' Tacoma coils 3'' Toytec Spacer lift with 1'' Diff Drop. 3 1/2'' Downey Rear lift Coil Springs. 285/75R/16 Goodyear MT/R. Last edited by Stevo3; 03-05-2007 at 08:41 AM. |
#18 (permalink) |
A ride home in someone else's car?
__________________
#19 (permalink) |
but he said he placed 3rd.
__________________
#20 (permalink) |
So you basically line up and just jam the pedal until you get to the rev limiter and hold it there until your engine dies? How did you come in 3rd without your engine blowing up then?
__________________
:Marko: Supercharged 98 4Runner SR5 4x4 3.4L 4" Deckplate :: TrueFlow Air Intake System :: Magnaflow 18" Muffler w/ Resonator XM Satellite Radio (Roady 2) :: Autometer Boost Gauge :: Color Keyed Spoiler TOYOTA|moving forward
#21 (permalink) |
Red Neck Rev-off
I think i will start a motor rebuild shop & have a weekly "REV-OFF" I'm sure i can make some $$$$.
__________________
))LIVIN HARD & DIRTY(( Yota 4x4 "Well ya could be starting off wrong by calling her a "bitch" See the TOYOTA gurl deserves respect.Call her by name or give her one.Once in awhile patt her on the d(ass)h.Be good to her & she'll be good to you." K-THANKS |
#22 (permalink) |
now thats a good idea. put up a shop next to that school instead
__________________
#23 (permalink) |
This "rev-off" has to be the stupidest thing I have ever heard of... I mean seriously, WTF?
__________________
Brian 1998 4Runner SR5 |
#24 (permalink) |
person 1: I bet my rev is louder than your rev
Person 2: i bet i can hold my rev longer than yours. Person 3: why is my truck back-firing now?
__________________
96 4Runner SR5 S/C - 03' Tacoma coils 3'' Toytec Spacer lift with 1'' Diff Drop. 3 1/2'' Downey Rear lift Coil Springs. 285/75R/16 Goodyear MT/R. Last edited by Stevo3; 03-05-2007 at 01:15 PM. |
#25 (permalink) | |
Quote:
__________________
