Timing Belt and Tundra
Ok, much confusion!! What's the low-down on my 2000 V8 Tundra timing belt. I know the interval (90k) but is this a non-interference engine? Thanks!
FYI: The Tundra V8 is currently Toyota's only timing belt INTERFERENCE engine. The other Toyota interference engines have timing chains that drive the camshafts. I believe most Toyota engines are non-interference. If that belt breaks while you're tooling down the highway at 70 mph you're in a world of hurt.
There are advantages to belts. It results in a smoother valve train, cheaper to produce, quieter engine, less need to harmonic dampening and a few others I am sure.
Gadget
www.GadgetOnline.com
Gadget
06-01-2021 01:51 PM
Suprarossa
07-06-2015 05:21 AM
01, 05, 2000, 2004, 2005, belt, engine, interference, limited, recommendation, replacement, timimg, timing, train, tundra
