Timing belt replacement
Old 11-01-2003, 09:23 AM
CLin9383's Avatar
I know most of you have replaced the timing belt. I just want an average ballpark price of how much that costs and if I had the water pump replaced with it. I have a coupon here that says it's 275 for just the timing belt, but there is a asterick that says "MOST 6 CYLINDER". Does that sound like a good deal if it falls under that coupon or am I looking at more than 300 dollars? Thanks guys
Old 11-01-2003, 10:31 AM
Sounds like a bit much to me. I just did my '91 V6 and the belt was about $30.00 and it took about 3 hours. You should be able to find someone to do it for around $200 or less, unless there's major differences between your '96 and my '91.
Old 11-01-2003, 10:38 AM
Henryv's Avatar
when i asked my dealor a few weeks ago i think it was 275 for labor + timing belt withtout any coupons
Old 11-01-2003, 01:03 PM
Arsrmk's Avatar
Wootersen, did you replace your timing belt yourself? If so, did you need any special tools or was there anything really difficult about it? I have about 90,000 miles on my current timing belt and was thinking about doing it myself to save some money, but wasn't sure if I should attempt it or not.
Old 11-01-2003, 01:33 PM
Vato Loco's Avatar
I got my timing belt changed about 4 weeks ago. It came to about $500cdn+ including labour, time and also got my spark plugs changed.
Old 11-01-2003, 01:52 PM
CLin9383's Avatar
whoa VATO!!!!! tha'ts $375 US dollars. I was hoping it wasn't much more than $275. If I do the water pump it would be closer to $500 right? Hey TOR, how much do you guys charge for timing belt and water pump? Thanks
Old 11-01-2003, 02:08 PM
MTL_4runner's Avatar
It isn't too bad to do it yourself as long as you are at least a bit mechanically inclined. Be very careful about where everything goes and take pics if you need to (digital cameras are great for this). Only thing special you will need is a chain wrench and a big piece of pipe (like 3' to 4' long) to slide over the ratchet handle. You need these to get the crankshaft pulley bolt off. That will be by far the hardest part. Might wnt to change all the drive belts while you have em off if they need it.
Good luck!
voiddweller
19
05-02-2016 09:10 PM
stagger_lee
03-29-2016 06:27 PM
layifioren
10
07-06-2015 02:26 PM
marcusSRG
06-27-2015 07:13 AM
infinityisfive
06-16-2015 06:51 PM
Quick Reply: Timing belt replacement
