ticking noise and oil pressure??
when my truck is warmed up to operating temp and at idle it has this ticking noise...rev it up just slightly and it goes away...all i have is a factory style oil pressure gauge that came with my cluster swap and it reads between the L and the first line on the gauge at idle...i know the 22re is supposed to have lower pressure at idle but should it be that low...seems like it should at least be to the first line...i'm running 5w30 oil maybe 10w30 would clear it up...i dunno...what do u guys think
My pressure is in that same range...between the L and first line. I've got the 6 banger in mine but mine runs great with the oil pressure being where it is.
Fink
Fink
yea, mine runs great...remaned engine, installed enginebuilders oil pump, waterpump, timing chain kit, and timing chain cover...just that ticking at idle...i took it to the stealership the other day and the tech that looked at it was like it runs fine but i dunno what that noise is....he wasn't much help at all...
My oil presure sit just past the first line when I am diving which has made me a bit concrened since I bout the truck (22re) but it has always been like that. I'ts good to hear you guys have low presure also, mabe it's normal. It will go down to noting if I sit at an Idle for a long time when it's warm.
Sounds like injector ticks or the normal valve train noise. The normal pressure for a warm engine at idle is between 5-9 for a 3.0 so I would think the 22r is not to far off those specs.
Yeah, the 3.0's are just a naturally noisy engine...I'm used to it now. But I do not notice a difference in noise that is dependant on the oil pressure.
Fink
Fink
Originally Posted by hub_01_69
do you guys hear any type of noise that is different at idle when the pressure is really low compared to when it's not at an idle?
Odin
07-15-2015 09:28 PM
88yodabasket
07-13-2015 01:32 PM
