Throttle Body A/T vs. M/T
Old 06-01-2011, 10:51 AM
1996Tacoma's Avatar
Hello,
I am purchasing a new throttle body for my 1996 Tacoma as mine is worn out.
From viewing this website: http://www.woodfins.com/Parts/1996-T...le%20Body.html
It looks like you can order an a/t or m/t throttle body. I was unaware that there was any differences?
Is every 5VZFE throttle body the same for the same year?
Thankyou
Old 06-01-2011, 03:52 PM
swampfox's Avatar
If I remember right the m/t has a dash pot on it and the a/t doesn't.
Old 06-02-2011, 08:29 AM
TheDurk's Avatar
That's interesting. My stock 5sp TB has the dashpot, but also has the empty third cable wheel for the A/T kickdown which is obviously not needed.
Old 06-02-2011, 09:15 AM
coastal runner's Avatar
wait... toyota parts wear out?
Old 06-02-2011, 09:19 AM
1996Tacoma's Avatar
haha.. unfortunately my butterfly valve has a gap from the cylinder bore allowing extra air thru increasing my idle. Yep I guess metal on metal does wear out eventually even if it is yota!
Old 06-02-2011, 09:39 AM
4x4climber's Avatar
guess it's time to rebuild, bore it and get a bigger flapper... =D
Old 06-02-2011, 09:43 AM
thats an interesting idea. idk about the 3.4s, but on my 3.0 TB theres an idle adjustment scew. maybe you could turn yours down and save some $money$
Old 06-03-2011, 02:45 PM
turbo8's Avatar
I made the mistake of cleaning my TB, which caused it to idle high.
I fixed it by filling the gap in my throttle body with high temp silicone.
Old 06-03-2011, 02:49 PM
1996Tacoma's Avatar
turbo8 sometimes the high idle after tb cleaning is caused by all the junk and cleaner running down into your IAC which is underneith the TB. Thanks for the high temp silicone tip. Do you see any problem with the silicone wearing off and going in to the engine?
I am getting another TB from the wreck yard for $60. Hopefully that should fix it.
Old 06-03-2011, 07:38 PM
turbo8's Avatar
I tried all the tricks to fix it, including a new IAC. Silicone can't be worse than the gunk build up that was already in there.
06-01-2021 01:51 PM
Blamalam
08-16-2015 12:29 PM
mtc1105
08-04-2015 08:06 PM
bighaydn
08-04-2015 07:17 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Quick Reply: Throttle Body A/T vs. M/T
