Throttle Body Overbore - TPS - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-17-2005, 02:10 PM   #1 (permalink)
irott's Avatar
I have been looking into this and a few questions came up that I searched for but couldnt find the answers to.
What adjustments, if any, would need to be made to the Throttle Position Sensor?
Will the ECU need to be adjusted as well?
There just isnt much info on yotatech about this.
__________________
[1992 4runner Limited]
___________________________________________
3.Slow (155k miles and still running strong)
irott is offline
Old 11-17-2005, 02:21 PM   #2 (permalink)
snap-on's Avatar
Send a message via AIM to snap-on
no adjustments to the TPS the butterfly moves just as much/little as before it was bored
the ECU doesnt care, all the air has to pass over the flapper way down stream. Your just creating an easyer path for the air to flow into the intake plentum. (but still have to go through like a 3 sqin area were the AFS is.
__________________
94 EX cab, 5speed, V6, locked, ARB bar, NWOR headers
92 4runner, auto, V6, OME suspension, Downey headers
snap-on is offline
Old 11-17-2005, 02:45 PM   #3 (permalink)
irott's Avatar
Thanks for the reply.
I found some more info on off-road.com about the TPS.
__________________
irott is offline
Old 11-17-2005, 02:51 PM   #4 (permalink)
rimpainter.com's Avatar
If you are simply doing a taper-bore to the butterfly, no adjustments are needed. I did it on mine. The gain, if any, was too small to detect.
rimpainter.com is offline
Old 11-17-2005, 03:27 PM   #5 (permalink)
Sponsoring Member
midiwall's Avatar
Quote:
Ditto.
__________________
~ Mark
'96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams
midiwall is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Throttle Position Sensor (TPS) on '01 4Runner w/supercharger Andrey 95.5-2004 Tacomas & 96-2002 4Runners 1 08-31-2006 05:00 AM
Throttle Positioning Sensor TPS 22re brendonv The Classifieds GraveYard 1 07-03-2006 07:51 AM
TPS help and Throttle Body Removing Rays94runner 95.5-2004 Tacomas & 96-2002 4Runners 5 09-08-2004 08:31 PM
Throttle Body Overbore? CBDenver Off Topic Talk 1 10-24-2002 01:01 AM
Throttle Body Overbore/ Air Intake Mod CBDenver 95.5-2004 Tacomas & 96-2002 4Runners 4 10-23-2002 02:56 PM
2009 InternetBrands, Inc.
