Thoughts on Wheel Adapters
Old 07-16-2005, 02:48 PM
tarheelrunner's Avatar
I had looked into getting some new wheels for the 4runner, but after looking around I don't know that I want to spend $600++ on new rims when my main goal is to widen the 4runner's track a little and pull the tires out from under the fender.
Anyway, I've looked into possibly getting some 1 or 1.5 inch Marlin wheel spacers/adapters. Just wanted to see what people think of these, and if they have any negative effect of the handling/ride quality. Thanks guys.
Old 07-16-2005, 04:56 PM
jimbo74's Avatar
they might accelerate stress on the bearings... personally i hate all wheel spacers, but the kind that actually use their own studs are tons better than the slip-on ones.... if you look at the Marlin ones or similar, its like $160 for a set of 4.... I would personally get new rims with proper offset and not needing to worry about torquing 48 lunuts when doing a tire rotation
Old 07-16-2005, 07:19 PM
You've got a point with the 48 lugnuts, but I'm assuming you don't rotate the wheel spacers too so I wouldn't think it would be too big a pain.
My main concern is ride quality and obviously safety, so I was hoping to here some reviews from guys who have run or are currently running some wheel spacers.
Old 07-30-2005, 10:42 PM
ecchamberlin's Avatar
bump for this thread cause I am interested in opinions on wheel spacers also. any comments? 1-1.5" spacers
Old 07-31-2005, 07:48 AM
4Crawler's Avatar
I've run spacers for many years. Recently put some 1.5" bolt-on spacers on until I get my wider rear axle installed. They have all worked fine. I like the flexibility spacers give me, I run 2 sets of wheels/tires and need different amounts of spacers for each set. And when running my narrow wheels/tires, I can pull the spacers and run narrow for long road trips or add spacers to push out the track width if I want to take the narrow tires off-road and need the extra stability.
I check the torque on the bolt-on adapter (1.5") whenever I have the wheel off. Nothing has loosened up yet.
kazuya2416
04-05-2024 02:17 AM
Massmayhem247
07-24-2015 12:07 PM
rushw
07-18-2015 01:46 PM
crashburnoveride
07-10-2015 06:39 AM
Edionne13
07-09-2015 01:59 PM
Quick Reply: Thoughts on Wheel Adapters
