For Those Who Are Going To Do The Differential Breather Mod.... - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-15-2006, 02:02 PM   #1 (permalink)
fireteacher's Avatar
I think that this a better/cleaner look to the mod. All you do is push in on the gasket around the filler neck to expose the metal ring holding the gasket in. pull the ring out and pull the gasket of one side of the filler neck with some needle nose pliers. Then feed your hose FROM the filler down to the differential, tighten everything up and cut your excess hose at the filler. I pushed in some extra hose just in case. Push the gasket all the way back around the filler neck and put the metal ring back in and your done. I just thought i'd sher the photo and maybe help out the ones new to this like me! In robinhoods write up in the off-road enhancements section, he shows what it looks like with out the gasket. I just thought it was there for a reason and wanted to kep the mud and stuff out.
__________________
Shaun
99 limited 4runner 3.4L
MODS: TJM-17/Sonoran shackle hangers/driving lights - DIFF Breather - Sliders - Cobra 19 ULTRA III cb and 3ft. Wilson ant - 265/75/16 Definity Dakota A/T - "SATOSHI MOD" - All Weather Mats - Locker Mod - Fog Light Mod - Vortex Classic Muffler
My profile http://yotatech.com/showthread.php?t=96117
fireteacher is offline
Old 04-15-2006, 02:59 PM   #2 (permalink)
spindleshanks's Avatar
I agree, behind the fuel door is the logical place to relocate it...
__________________
'03 beauty of a white Tacoma, check it out:
http://www.yotatech.com/f83/spindles.../#post50606613
"The fingers you have used to dial this number are too fat. For information on how you can obtain your own personal dialing wand, please mash your palm against the keypad now."
spindleshanks is offline
Old 04-15-2006, 03:04 PM   #3 (permalink)
calrockx's Avatar
Send a message via AIM to calrockx
looks good. i just used an xacto-knife to cut a slit in the gasket and slipped the breather tube through that.
__________________
[2002 4Runner 4WD]
calrockx is offline
Old 04-15-2006, 03:37 PM   #4 (permalink)
d0ubledown's Avatar
Send a message via MSN to d0ubledown Send a message via Yahoo to d0ubledown
i just did mine recently, and didnt bother putting it through the rubber gasket. its just ziptied to the filler neck, just behind the rubber. it was dark and i couldnt be bothered with fiddling with the gasket. maybe one day ill put it through.
do this mod if you go anywhere near water/mud! its too easy not to...
__________________
sonny
1998 4Runner LTD. Fabtech CO fronts, OME/Pro Comp rears, SS rear links, Revtek diff drop, oem elocker, ARB RD90, 4.88's, 315/75/16 MT/R's on FZJ-80's, Trail Gear sliders, ARB Prado Bar, 1.5" 4Crawler BL, Tundra Brakes, wabfab disco's, IPF's...satoshi'd deckplated & ISR'd.
SOLD!!!
new ride: 1997 FZJ80. ome/arb/bfg/etc.
when clinton lied..nobody died
d0ubledown is offline
Old 04-15-2006, 05:41 PM   #5 (permalink)
agreed! just thought id share my variation! on the 4runner its a pain to get to the filler neck cause you have to remove a piece out of the fender-well and i didnt want to play that game!
__________________
Shaun
Old 04-15-2006, 06:03 PM   #6 (permalink)
habanero's Avatar
Send a message via AIM to habanero
Mine's behind the gasket like dOubledown's.....just removed the gasket to get to the filler neck and was able to zip tie it from there. Course, I've got long fingered chick hands so sometimes I can get into a spot larger hands can't.
Yours is a great idea, glad you shared.
__________________
My rides:
'96 4Runner SR5 4x4, manual. Deckplate, ISR, extended rear diff breather mods, flipped receiver hitch, power antenna switch, Garage door opener switch in dash, Kill switch somewhere in there, Thule playpen, system 1.2 installed without any swear words even when my kid walked off with my tools........
Quote:
Originally Posted by Tacoclimber View Post
Habanero - you ride a Gary Fisher, you change your own oil, AND you have a man-eating pumpkin pie as your avatar. You are anything BUT a soccer mom. :D
habanero is offline
Old 04-15-2006, 07:15 PM   #7 (permalink)
bflooks's Avatar
me and lee's are like that. i like that it is safe from all the splash from the wheel well and also safe behind the door. plus, it reminds you to keep an eye on the breather and also to check the passage of the tubing every once in a while as well.
bflooks is offline
Old 04-15-2006, 07:39 PM   #8 (permalink)
exactly why i did it like that
__________________
Shaun
Old 04-16-2006, 08:04 PM   #9 (permalink)
Wazioc's Avatar
ok... just food for thought here. If you were to go in water that happened to be up to your fuel door, would you want it behind the gasket so that water doesnt just rush in the crack around the fuel door, or would the same thing happen even if it were behind the rubber gasket? I have been wanting to do this mod, but havnt gotten around to ordering the parts yet.
Wazioc is offline
Old 04-16-2006, 08:42 PM   #10 (permalink)
i really dont plan on putting the runner in water that deep EVER! this is mearly for when im in the rivers and big puddles...deff ont want to swim around in the interior!
__________________
Shaun
Old 04-17-2006, 06:23 AM   #11 (permalink)
bflooks's Avatar
pretty much...even if it were behind the rubber piece, it would still be under water. i like this for simplicity, cleanliness, and like i said....a reminder.
bflooks is offline
Old 04-17-2006, 06:56 AM   #12 (permalink)
Ditto!
__________________
Shaun
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
differential breather Just Learning General Vehicle Related Topics (Non Year Related) 6 10-31-2006 07:07 PM
Rear Differential Breather Mod Robinhood150 Off Road Enhancements 0 01-07-2006 07:38 PM
New Mod: 3.4L TB Bore Mod, “O” Gasket Mod, and PCV Breather Mod – with pics rimpainter.com 95.5-2004 Tacomas & 96-2002 4Runners 127 02-11-2005 06:47 AM
Differential Breather Mod w/pics rimpainter.com 95.5-2004 Tacomas & 96-2002 4Runners 17 03-10-2003 07:05 PM
2009 InternetBrands, Inc.
